Old 08-31-2002, 04:42 PM   #1
Stroker
Question Western Chassis dropped spindles
A few years ago I picked up a set of Western Chassis dropped spindles and I'm just now getting around to putting them on. I was told they are actually for 73 up and required different upper ball joint and outer tie-rod. No problem that went smooth. Anyway I went to install the spindle washer and nut, something doesn't seem right. The washer and nut are both slightly small. The correct factory size is 3/4 x 20 for both the 72 and 73 I thought. There doesn't seem to be any burrs on the threads but when I measured them they are about .040 larger than the stock 72 spindle. (measured @.780 outside with dial calipers) Do they make castle nuts that size do they? Anyone have any ideas. Thanks......Stroker
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
