Old 03-07-2007, 03:44 AM   #1
oveeets
rear hatch opennings
anyone swapped out stock hatch hinges w/ gas shock type???
1969 burban w/ clam shell style.
STEEEVO 69 BurB
oveeets is offline   Reply With Quote
Old 03-07-2007, 07:11 AM   #2
Re: rear hatch opennings
No,but wondered about it.I wonder if you can get them the right length with a heavy enough pre-load.Most lift hatches that use those are full hatches (longer)and either fiberglass,glass,or just much lighter construction.There may be a compatable unit.Finding it is your first challenge.
Old 03-07-2007, 09:03 AM   #3
Hart_Rod
Hart_Rod's Avatar
I did a complete write up with part #'s in the FAQ.
http://67-72chevytrucks.com/vboard/s...d.php?t=220511
If you have all the parts it should take you less than an hour to do.
R
Hart_Rod is offline   Reply With Quote
Old 03-08-2007, 06:16 AM   #4
oveeets
Question Re: rear hatch opennings
what are the opened & closed dimensions you used ???
what is stock ???
STEEEVO 69 BurB
Old 03-08-2007, 07:31 AM   #5
Hart_Rod
Hart_Rod's Avatar
what is stock ???
It opens and closes the same as before.
