Electrical help
My truck battery is draining almost nightly. So far I've replaced the battery and alternator (needed to upgrade to an Interstate battery and a chrome alternator anyway
![]() Thanks ahead of time for any help.
1970 C10 ![]() |
#2 | |
Re: Electrical help
Here's what Bob has to say about that;
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper Last edited by FLEET72; 03-07-2007 at 10:48 PM. Reason: spelling err. |
Re: Electrical help
Good info to have, Fleet.
1969 C/10 swb, 350, powerglide (daily driver) 2005 CRV (wife's ride) |
Re: Electrical help
![]() I actually think the starter IS shot. I can't duplicate the noise it makes in this post. But you get the idea. I bought some shims, but maybe I'll go for the rest. I'm going to do the fuse thing first, though. Thanks!
1970 C10 ![]() |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Electrical help
If it was stuck points in the regulator you would have quite a spark when you disconnect the battery cable. It isn't a direct short to ground because you would have blown a fusible link or burnt the harness. A lot of these are caused by the horn wire under the steering wheel grounding and energizing the horn relay. If that was the case the horn should blow unless it has been disconnected. My .02
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: Electrical help
So far it looks like the alternator I bought was a bad one. I exchanged it, reclocked that one, and installed that one. So far it starts right up. Now it sits for a few days. That will be the real test.
1970 C10 ![]() |
