Old 03-07-2007, 10:48 PM   #1
OleBlue69
OleBlue69's Avatar
Smile Electric Fuel Pump Install
Got me a Holley "Blue" electric fuel pump yesterday. Where do you guys have yours mounted? I was thinking on the inside of the frame near where the mechanical pump was. Pictures are most definitely welcome! Also, are yall using any type of emergency shut-off for your pumps, if so what kind? Holley has a shut off switch that operates off of oil pressure. So, no pressure, no pumping.
Thanks guys.
OleBlue69 is offline   Reply With Quote
Old 03-08-2007, 12:38 AM   #2
dinnut
dinnut's Avatar
Re: Electric Fuel Pump Install
i just bought one of these as well.mines gonna be fueling my fresh 383 though. yeah id like to see some ideas on how people are mounting them... i originally bought cheap parts store brand pump and found out they overfueled like a mofo so i invested in the holley. hope theyre of good quality
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 03-08-2007, 10:21 AM   #3
OleBlue69
OleBlue69's Avatar
Come on, I know you some of you have electric fuel pumps on your trucks??
Dinnut, what's the specs on you 383? That's what's in my truck.
Vortec heads, bigger valves, bowl work
Comp XE262 hydraulic cam
10.2:1 compression with speed pro pistons and eagle bottom end
Performer RPM intake and roller tipped rockers
Old 03-08-2007, 10:27 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I would think you would want it mounted as close to the tank as possible.
sneakysnake is offline   Reply With Quote
Old 03-08-2007, 10:34 AM   #5
cableguy0
i mounted mine on the outside of the frame rail on the passenger side it sits just a tad forward of where the door handle is. electric pumps need to be as close to the tank as possible. underhood is not a good place for them the heat will kill it. you also want to keep it away from exhaust. electric pumps push a lot better than they pull which is why you want it close to the tank.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-08-2007, 01:07 PM   #6
williamt
68 just like me
williamt's Avatar
Generally electric pumps push better than they pull so the closer to the tank the better.
68 just like me
williamt is offline   Reply With Quote
Old 03-08-2007, 01:09 PM   #7
williamt
68 just like me
williamt's Avatar
ok I should have read the last post first now I sound like an echo
68 just like me
Old 03-08-2007, 01:13 PM   #8
OleBlue69
OleBlue69's Avatar
I got to looking and it is too tall to fit inside the frame. Didn't think about the heat or keeping it close to the tank, so I guess it works out anyway. I will check out the frame under the cab after lunch. I'm trying to get this thing finished up before spring break is over and I have to head back to school. Guess we'll see what happens....
Thanks for the help and keep the tips/suggestions coming!
Old 03-08-2007, 03:10 PM   #9
tracterman2
tracterman2's Avatar
we do this on dodge diesels often...they have a carter pick up pump mounted on the fire wall....BAD PLACE...they are pusher pumps and not designed to pull...so they have alot of trouble with them...you can still put it on the frame just take you a small piece of flat metal and either bend the edges or tack it to the top and bottom of the frame. Then mount the pump to this plate...works well..most of the replacements for the dodge trucks won't fit within the frame. If you can do it, use aluminum, it will act as a heat sink for the pump as well...hope this helps but put it close to the tank is the main thing, and keep it cool.
I'm Your Huckleberry.
You Ain't No Daisy.
tracterman2 is offline   Reply With Quote
Old 03-08-2007, 06:39 PM   #10
bill_in_sd
bill_in_sd's Avatar
Any recommendations on filter location, or do you strictly rely on the filter in the carb?
Bill in SD
1971 GMC 1 Ton Custom Camper - I think....
bill_in_sd is offline   Reply With Quote
Old 03-08-2007, 06:42 PM   #11
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Definatley put a filter BEFORE your pump. Most pump manufacturers won't even warranty one if there wasn't a "pre-filter" installed. I always use one after too, just in case.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 03-08-2007, 07:02 PM   #12
Rascal_one2001
Rascal_one2001's Avatar
I just hooked my red holley fuel pump( The one for carbs) and I mounted mine on the outside of the frame rail since it it a little to tight on the wire to put it in side the frame rail . It is a little above level with the bottom of the frame and it is a couple inches in front or my rear cab mount . The filter is right after the metal line comes out of the floor of the cab. It sucks not having my camera right now but it is what it is.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 03-08-2007, 07:11 PM   #13
Rascal_one2001
Aern't the blues for 14 psi or are you running fuel injection?
Old 03-08-2007, 07:43 PM   #14
bill_in_sd
bill_in_sd's Avatar
Has anyone had problems running the higher gpm types?
Maybe that is why one quit on me - it may have been working against itself - I did not have any type of pressure switch on it or anything.
Bill in SD
Old 03-08-2007, 08:03 PM   #15
dog68chevy
New Member
dog68chevy's Avatar
holley blue pump pressure is higher then 7psi most needle&seats dontlike that make sure you use the regulator .put a filter between the tank and pump
dog68chevy is offline   Reply With Quote
Old 03-08-2007, 08:30 PM   #16
cableguy0
the holley blue pumps come with a regulator for a couple dollars more than the red pump and is definately not a fuel injection pump it is a carb pump.fuel injection pumps are usually around 50 psi or so aside from gm tbi which is about 15 psi. i have been running a blue pump for a couple years with no issues you just have to set the pressure with a regulator.as stated put a filter in front of the pump so a lot of trash doesnt get in there. the pumps have a brass screen inside but they clog very easily so you need a pre filter.
Old 03-08-2007, 11:20 PM   #17
OleBlue69
OleBlue69's Avatar
The instructions that came with the pump said to run a screen filter before the pump and a high quality filter after the pump. Also, I got the one with the regulator, so I will adjust my pressure accordingly. What is a good pressure to adjust the regulator to? I have a pressure gage on my fuel lines for the carb.
I think I am going to mount my pump on the inside of the frame rail, passenger side. It will be right below the area where the fuel line from the tank runs down to the frame rail. I don't guess I can get it much closer unless I put it in the cab. I figure it will be better protected from road debris being on the inside. But, do you guys think it will get too hot being on the inside with potentially less air flow?
Old 03-08-2007, 11:48 PM   #18
BACKYARD88
BACKYARD88's Avatar
I'd run the pressure between 5-7 PSI. Heat shouldn't be a problem as long as it isn't too close to the exhaust.
-Mike Owen-
Old 03-09-2007, 12:12 AM   #19
Rascal_one2001
I started to put mine inside the frame rail but mine would have been a really tight fit and with the wires on the top pinched between frame and pump I was worried that mabe vibrations could wear thew the wires and ground out my fuel pump. mabe I am being over nervious but to late now I got it all hooked up now.
Old 03-09-2007, 12:58 AM   #20
kelsfine69
18 Till I Die
kelsfine69's Avatar
mine
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-09-2007, 01:43 AM   #21
jrb71c20
jrb71c20's Avatar
Previous owner had one and it crapped out...I replaced it with a cheaper one and mounted where the old one was, on the inside frame under the cab. The only other thing I did was add a toggle switch.
93 Sonoma 2.8/5spd
75 Malibu Classic 350/350
If it don't have round headlights and a carb, I don't trust it!
jrb71c20 is offline   Reply With Quote
