Old 03-07-2007, 11:05 PM   #1
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Tach Sticks
I have a Camaro tach in my truck. It sticks at 2200rpm. The only way to get it unstuck is to drive over some bumps. Any ideas why it sticks?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 03-08-2007, 06:31 AM   #2
71see10
Worthless
71see10's Avatar
Re: Tach Sticks
TTT for you, I'm having the same problem with 2 of these!!
71see10 is offline   Reply With Quote
Old 03-08-2007, 07:19 AM   #3
'72hemieater
DODGE SMACKDOWN CLUB
'72hemieater's Avatar
Re: Tach Sticks
buy a better tach
George Bush hates midgets
'72hemieater is offline   Reply With Quote
Old 03-08-2007, 08:01 AM   #4
ghackett1
68 C10 Longbed
ghackett1's Avatar
Re: Tach Sticks
What's up with that. I also bought a restoration tach for my 72 Z28 and it idles perfect up to 2400 RPM and then stops like its stuck! Does anybody have one that registers above 3000??
ghackett1 is offline   Reply With Quote
Old 03-08-2007, 08:47 AM   #5
badpeanut
badpeanut's Avatar
Re: Tach Sticks
The factory one in my 1980 Camaro works perfectly.
'70 GMC LWB trailer
Old 03-08-2007, 08:57 AM   #6
Huck
Huck's Avatar
Re: Tach Sticks
Not all that familiar with the camero tachs but --the original truck tachs are not the greatest in accuracy or design. Sometimes some of the foam tape used to edge the protective cardboard circular cover comes loose and gets inbetween the magnets and the armature causing a bind. Common problem. You would need to carefully disassemble the thing to check for junk in there. I have found foam, dust, dirt, dead bugs, etc stuck in them from time to time. Good luck--Huck
Huck is offline   Reply With Quote
Old 03-08-2007, 09:43 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Tach Sticks
would the dirt, dust, ect. be the same thing with the speedo for these trucks if it stops at say 85mph and wont go over??? but works fine under 85 but just wont go over 85
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-10-2007, 01:22 PM   #8
badpeanut
badpeanut's Avatar
Re: Tach Sticks
Originally Posted by '72hemieater View Post
buy a better tach
What tach is better?
'70 GMC LWB trailer
Old 03-10-2007, 01:28 PM   #9
see ten
WTB this ad
see ten's Avatar
Re: Tach Sticks
buy a better tach
This will be my new response for anyone with a problem! I will simply substitute the word "tach" with things like.....engine, wheels, transmission, rearend, radio, drop, fenders, headers, A/C, wiring harness. Wow suddenly I can solve everyones problems on the board! Thanks for the laugh and the inspiration!
see ten is offline   Reply With Quote
