Old 03-07-2007, 11:51 PM   #1
cajundragger
started my ls6/t56 swap...
loaded up...
engine, meet trans
droped in the frame...
almost there, hadda cut a decent amount of the floor out...
bam...
cajundragger is offline   Reply With Quote
Old 03-07-2007, 11:53 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: started my ls6/t56 swap...
awesome, cant wait to see it
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 03-08-2007, 12:43 AM   #3
1lowdiesel
1lowdiesel's Avatar
ooooo 6 speed... nice fullsize too
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 03-08-2007, 09:18 PM   #4
cajundragger
thanks man, yeah the fullsize got pushed to the side for this project...
got the trans member in today...
the drivers mount has to go back to clear the steering so I guess I just bolt the actual mounts off the engine in the other holes on the block and push the mount back on the frame...
Old 03-09-2007, 10:21 AM   #5
Kabwe
Certified Car Nut
Kabwe's Avatar
Its looking real good. Keep up the good work
Kabwe is offline   Reply With Quote
Old 03-10-2007, 10:28 AM   #6
chevyrestoguy
chevyrestoguy's Avatar
That thing is going to be one quick truck. Keep them pictures coming! Seeing your progress makes me want to scrap my big block idea and build one of those. Some many directions to go to achieve the same end.
________
ARIZONA MEDICAL MARIJUANA DISPENSARIES
chevyrestoguy is offline   Reply With Quote
Old 03-11-2007, 10:22 PM   #7
cajundragger
well I really dont have anymore pics of the actual engine mounting. I did have one problem...my bisket stlye engine mounts come into contact with my steering rack...so the drivers side mount got pushed back and my mounts are now offset. It looks retarded but will work fine...
Old 03-12-2007, 12:51 AM   #8
Daniel U
Daniel U's Avatar
Should be a quick ride!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 03-12-2007, 08:43 AM   #9
texascowboy593
texascowboy593's Avatar
Very nice!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 03-12-2007, 11:59 PM   #10
cajundragger
Im hoping for 11's on motor with this setup...only major problem will be traction and a track that will actually let me run...
Old 03-13-2007, 12:28 AM   #11
84 400
Sb 400 club
84 400's Avatar
great choice on the trans and nice parts getter caint wait to see the rest of the truck putogher
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-14-2007, 10:52 AM   #12
Jebb1978
Jebb1978's Avatar
Those frame mods are wild man! I like it ! This will be a fun build to watch.
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 03-15-2007, 07:22 AM   #13
Detroit3100
why wont the track let you run?? I am in the same boat, LQ9 into a 50 and I need to run it on the track!
Question: how much of an angle did you set the engine back @??? I have to set mine in and nned to know how much it should lean back?
thanks
good work-
Detroit3100 is offline   Reply With Quote
Old 03-15-2007, 10:56 AM   #14
1-ton of fun
polishing a turd
1-ton of fun's Avatar
traction shouldn't be much of a problem with good tires and a proper suspension. the only problem with tech at the track would be if you run faster than 11.50, then you would need a 5 point roll bar.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 03-15-2007, 08:21 PM   #15
cajundragger
and my truck drags the ground..so I wont pass tech even if I run a minute...
but I am hoping for 11.50's
Old 03-16-2007, 11:28 AM   #16
1-ton of fun
polishing a turd
what do you mean? how will it not pass tech?
Old 03-16-2007, 06:21 PM   #17
cajundragger
because if an airbag or line or vavle go bad the truck will fall on the gorund(literly)
Old 03-19-2007, 12:02 PM   #18
1-ton of fun
polishing a turd
hmm, didn't know about that. (not that it affects any of my cars)
Old 03-23-2007, 11:42 AM   #19
Detroit3100
but my truck is set up to stop on the bump stops if they deflate, does that mean I will have to find springs
Old 03-23-2007, 01:24 PM   #20
cajundragger
depends....my truck literly falls on the fenders/running boards..so if it doesnt touch the ground then your golden...
