Old 08-31-2002, 08:49 PM   #1
lux hauler
Psycho-billy Member
lux hauler's Avatar
Brake line removal
I'm puttin new wheel cylinders on my truck and I can't get the brake line off the back. Is there some kinda trick to this
I'm afraid I'm gunna booger up the nipple.
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 08-31-2002, 09:22 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
No trick...just good 'ole mother nature doing her best to keep our northern trucks from rattling apart. (that would be rust for all you non-knowing cali ppl who have never seen a rust hole)
Old 08-31-2002, 09:26 PM   #3
lux hauler
Psycho-billy Member
lux hauler's Avatar
I soaked it good yesterday but it still won't turn.
What is that nipple made of?
'72 C-10
Old 08-31-2002, 09:30 PM   #4
Longhorn Man
Rust aperantly...just like mine.
You refering to the bleeder valve, or the incoming brake line fitting?
Wither way, it is normal steel if I am not mistaken.
Old 08-31-2002, 09:33 PM   #5
lux hauler
Psycho-billy Member
lux hauler's Avatar
The brake line fitting.
Well, I guess if I mess it up I'll just have to buy a new line.
Thanks 'mail
'72 C-10
Old 09-01-2002, 01:40 AM   #6
junkyardjohn
junkyardjohn's Avatar
Thumbs up
I LIVED IN MICHIGAN FOR 35 YEARS, SO I'M WELL AQUAINTED WITH THAT BROWN SH!T CALLED "RUST". THE BEST WAY I'VE FOUND TO REMOVE THEM, IF YOUR GONNA HAFTA REPLACE THE LINE IS TO NIP THE LINE OFF WITH SIDECUTTERS (OR DIKES) & PUT A 6 POINT SOCKET ON THEM.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-01-2002, 02:05 AM   #7
jostrans68
Jostrans68
jostrans68's Avatar
I always use a small pair of vice grips and i get them out about 90% of the time and the are still useable
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 09-01-2002, 02:24 AM   #8
hjalbert
cracker
hjalbert's Avatar
my tip, from experience, is to use vice grips, and if you break the brake line, then inline tube can hook you right up, i decided to order a whole set off stainless lines, when i found out shipping would be the same for that as it would be for on little line, got all the lines for my 69 swb 4wd for under 200 delivered. i think it was worth it.. imho
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 09-01-2002, 08:42 AM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
If the lines look "iffy", just replace them. If your sure they are in good shape, spray the end with WD-40 and tap with a hammer. Then lock a vise grip on and give one good smack to break loose. Most times, this will work. For the other 1% of the time you'll have to replace the line.
This is a good time to replace all the lines if they've been on for a long time. They are cheap and you have to bleed the brakes anyway...
Tip: Be carefull how you run the lines. I had one rub through as it was scraping against the frame. I just replaced that yesterday. It started out as continually losing a little fluid and was driving me nuts because I coudn't find it! Yesterday it let go No mistaking where it was coming from after that.
Brakes are a serious thing. Never skimp when it comes to them.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 09-01-2002, 02:37 PM   #10
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I use a tube wrench and tap try to tap it toward tightening it then toward loosening it and that useually breaks the lines or the bleeders free. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-01-2002, 03:33 PM   #11
Duner97
Duner97's Avatar
us cali people dont know rust?? wow! thought i'd never hear that. i just moved from the coast and after a couple nights of leaving my quad an the beach, i had to clean the rust off my aluminum handle bars. had my old truck for 6 months. no rust when i bought it, had 3 or 4 spots of it under the paint when i sold it. its bad on the coast.
72 SB 4x4
-Duner97
Duner97 is offline   Reply With Quote
Old 09-01-2002, 09:32 PM   #12
Just did mine and had same problem. Like most said the vise grip to break it loose. For me the hardest part was the rear end. Had same trub with the bolts holding in the wheel cylinders. Had to break them loose with vise grips also.
Lots of WD40...Lots of patience... and a prayer or two helps...mostly so you don't rip you or the truck to shreds when they won't budge!!
Old 09-01-2002, 11:12 PM   #13
lux hauler
Psycho-billy Member
lux hauler's Avatar
I couldn't get it to turn so I cut the line.
I guess I'll be ordering a new set of stainless lines
Thanks for all the suggestions.
'72 C-10
Old 09-02-2002, 08:47 AM   #14
bobs409
bobs409's Avatar
Ah, now you can use a socket!
If you want to do this job alot cheaper, just go to the local auto parts store and buy some straight line and a tubing bender and flare tool. You can probably replace every single line for $15 dollars or less!
IMO, the idea of stainless steel lines is nice but I don't think really nescasary. It's more for the "truck that has everything".
Regular steel lines with a coat of paint from the start will hold up for a very, very long time. I have mine on for over 5 years now and not even a sign of rust yet. (and I drive mine everyday in all kinds of weather-Pa.) No rust on the inside either as I did have to replace one due to rubbing the frame-DOH!
It's your choice though.
Have fun
Bob
Old 09-02-2002, 09:16 AM   #15
Longhorn Man
I have to agree with bob...30 years is a pretty good life span for a brake line...
Old 09-05-2002, 11:42 AM   #16
Lippyp
English Chevy Owner
Lippyp's Avatar
Do you guys ever use copper brake lines? This is the most common material used here in the UK and will outlast steel by a fair stretch. It's nice and soft so easy to bend and flare and you can buy it by the roll. I have not seen stainless lines for any car here in the UK at all , maybe it just hasn't reached us poor cousins yet! We do know a thing or two about combatting rust over here, 2 inches of rain in just over an hour in the middle of August!....what a great summer. One job I need to try and do before the winter sets in is to spray all the cavities, box sections and underbody with anti-rust wax, a really messy stinky operation.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
