Old 03-08-2007, 11:33 AM   #1
dan42
dan42's Avatar
steering column maintenance-?
I had to replace my column shifter because it was worn out, and since I have it down this far, is there any maintainence that could be/should be done at this point? Everything seems to be working pretty good right now. Just wondering if there is any lubrication that could be done. Also, I read a thread that said you could shorten your steering column by loosening the brackets and pushing it forward, to give yourself more room - is that easier now? Thanks for your help in advance.
dan42 is offline   Reply With Quote
Old 03-08-2007, 12:24 PM   #2
mvfd70
mvfd70's Avatar
Re: steering column maintenance-?
I have a 3 speed column shift that was sticking. It went up and down just fine but it was really stiff going back and forth. I took the steering wheel off and tore the column down past the trun signal switch housing. It was really dry in there. Gave it a couple of squirts of WD-40 on the shifter shaft, Put it all back together, and it works like a charm. I say just keep it lubed up good.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 03-08-2007, 08:59 PM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
This requires compressing the intermediate shaft. If yours behaves like mine it means removing it from the truck and putting it in a hydraulic press.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 03-08-2007, 10:37 PM   #4
aboyer
Adam B
http://67-72chevytrucks.com/vboard/s...light=steering
Attached is the link to the shorten your steering column. I would highly recommend, and you are half way there at this point. I shorten my column a couple months ago, I it is a recommend "Must Do",
Adam
aboyer is offline   Reply With Quote
Old 03-28-2007, 11:28 PM   #5
1lowdiesel
1lowdiesel's Avatar
anybody have any pics of a manual column done??
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 03-29-2007, 02:54 AM   #6
oveeets
I JUST WENT THROUGH STEERING COLUMN ON 69 BURBAN W/ AUTO TRANS BECUASE IT WAS BINDING UP WHEN SHIFTING IN OR OUT OF PARK.
SO I GOT STEERING WHEEL END TO WHERE YOUR PICTURE IS & BASICALLY CLEANED ALL!!! PARTS & LUBED W/ HIGH TEMP BEERING GREASE SHAFT AREA WAS VERY GUNKED UP W/ OLD GREASE & CRUDD.
ALSO ON OTHER END TO STEERING BOX I DID THE SAME...CLEAN & LUBE DOES WONDERS ...NOW ALL IS SMOOTH..CHANGE ANY DAMAGED PARTS WHILE YOU'RE IN THERE..
STEEEVO 69 BurB
oveeets is offline   Reply With Quote
