Old 03-08-2007, 11:34 AM   #1
Mt Man Chad
Mt Man Chad's Avatar
Question Rocker panel plugs......
I removed the factory plus on the front edges of the rocker planels. Then used a garden hose to clean out all the bits of crap inside and flush the drains clean yesterday. They appear to be very clean and soild inside from front to back.
What is the best method to seal up the rockers inside from front to back to stop any future rust? .
Also does anybody know if you can purchase the factory plugs to cap the hole back shut?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 03-08-2007, 12:50 PM   #2
metalmassfab
Junior Member
metalmassfab's Avatar
Re: Rocker panel plugs......
My trucks a '69 C-20...and seafoam green too Sealing them up at this point will just make them rust from the inside out. Water can get in trough the front, bottom, underneath, sill plate screw holes...its just scary! I tried to seal the passenger side rocker on my truck to keep it from becoming like the drivers side (pic). Unknown by me, water was sliding down the door windows, dripping down inside to the bottom of the door, and on through the sill plate screw holes to fill up the rockers! The salty MO winter roads killed 'er off. Generally, if you seal something it needs to be rust free. Killing the rust with acid and hosing in some POR-15 is an option. That stuff works really good, even in marine applications.
Ryan
Metal Massacre Fabrication
New Projects:
-New radiator core supports, steel and stainless
-Aluminum radiators
-Aluminum dual electric fan shrouds
'69 C-20 Custom
'69 Nova...BIG BBC soon
'72 3-door 'Burb...in a few
'94 K2500 454 'Burb
metalmassfab is offline   Reply With Quote
Old 03-08-2007, 01:47 PM   #3
SactoJim
SactoJim's Avatar
The Truck Shop in southern California has the plugs.
I would just get it clean and make sure there is no more debri in there to collect moisture and/or block drainage. You could get some undercoating with a tip extension (straw) and try to spray it in there the best you can.
You just wanna make sure that any water that can get in, can get out.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
