Old 03-08-2007, 01:09 PM   #1
shaneschevys
Its always something!
shaneschevys's Avatar
Will a van front susp. work?
I have a chance to buy a running 75 chevy van. Will the front end fit under our trucks? Is the rear end the same as a truck with leaf springs? I am trying to figure out if it is worth getting & parting out.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 03-08-2007, 03:32 PM   #2
Bob Moore
Re: Will a van front susp. work?
I am not sure about the whole crossmember thing but here goes on individual items. Rotors, calipers, spindles, upper control arms, shocks, springs, center link and tie rods should fit. I have seen several vans with larger lower control arm bushings. They look different than P/U. Therefore I don't think the lower arms will interchange.
The rear end may have the larger diameter brakes which would be an upgrade.
Somebody has said the front crossmember is a different configuration - maybe frame width - than the P/U. I don't know for positive.
The spring rate may be different due to way the van is laid out - more weight over the springs and less overhang. Not sure on the ride quality if interchanged.
The other thing I would mention is that a van can be called a 20series and still have 5 lug. You have to go to 30series vans to get 8 lug.
Good luck and let us know for sure. I know vans are cheaper and are readily available in the junk yards.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-08-2007, 04:29 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I think the gear boxes are wrong, but the front member will work. but dont hold me to it.
sneakysnake is offline   Reply With Quote
Old 03-08-2007, 05:20 PM   #4
bobthecop
bobthecop's Avatar
Try calling a salvage yard and see if they will look it up for you, I've been told they have crossover books that tell what parts will interchange.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 03-08-2007, 06:21 PM   #5
john
member #16
john's Avatar
Check the width, that was brought up once.
john is offline   Reply With Quote
Old 03-08-2007, 07:15 PM   #6
Livrat
Member #1049
Livrat's Avatar
I just looked at one today.. The things I noticed different.. crossmember, motor mount towers, lower A frames and steering box. the rest appeared the same...
The rear ends are wider..
Livrat is offline   Reply With Quote
Old 03-08-2007, 08:33 PM   #7
rstewart09
rstewart09's Avatar
I bought a van for the motor and transmission to use in my 3/4 ton GMC. The van frame is wider and the front cross member would not work. I had hoped to convert to the 5 lug but after looking at it I just pulled motor and trans and gave up on the rest.
The start of a new toy
1967 GMC 3/4 ton
rstewart09 is offline   Reply With Quote
