Old 03-08-2007, 01:09 PM   #1
ckoett
Need a little help with VIN & Model #
Hey guys I have a 1971 GMC 3/4T 4x4 that has been in the family since new. It has been sitting for about 10 years after my dad used it around the farm the 20 years before that. I'm thinking about restoring it and need help deciphering all the codes. Any help will be greatly appreciated!
VIN - KE234-S118668 (From drivers side door jam...not sure if the 1's are 1's or I's)
Model # - KE25934 (From glove box door)
Thanks in advance
ckoett is offline   Reply With Quote
Old 03-08-2007, 01:58 PM   #2
1969k10stepside
Re: Need a little help with VIN & Model #
This is right off the VIN decoder on the home page of the site:
Chassis Designation (1st digit)
C= 4x2
K= 4x4
Engine Deisgnation (2nd digit)
E = V-8 Gas
S = Six Cylinder Gas
GVW Range (3rd Digit)
1 = 1/2 Ton
2 = 3/4 Ton
3 = 1 Ton
Model Code (4th Digit)
4 = Pickup with Cab and Bed
Model Year (5th Digit)
7 = 1967
8 = 1968
9 = 1969
0 = 1970
1 = 1971
2 = 1972
Assembly Plant
A = Atlanta
B = Baltimore
F = Flint
J = Janesville
N = Norwood
P = Pontiac
S = St. Louis
T = Tarrytown
Z = Fremont
1 = Oshawa
Vehicle Serial Number
100001 = 1st Unit Built
1967-1972 Model Number Codes
(The Model Number is located on the inside of the glove box door.)
Example: C E 1 09 9 34 J 100001
C = 4x2
K = 4x4
P = Forward Control
E = V-8 Gas
1 = 1/2 Ton
2 = 3/4 Ton
3 = 1 Ton
Cab To Axle Dimension (4th Digit)
07 = 42"-47"
09 = 54"-59"
10 = 60"-65"
12 = 72"-77"
13 = 78"-83"
14 = 84"-89"
15 = 90"-95"
7 - 1967
8 - 1968
9 - 1969
0 - 1970
1 - 1971
2 - 1972
Body and Brake (6th Digit)
02 = Flat Face Cowl
03 = Cab
04 = Stepside Pickup
05 = Panel
06 = Suburban
09 = Cab, Platform, and Stake Rack
12 = Windshield Cowl
16 = Suburban (Tail and Liftgate)
26 = Custom Suburban (Panel Rear Doors)
34 = Fleetside Pickup
35 = Foward Control (Square Front)
36 = Deluxe Suburban (Panel Rear Doors)
42 = Forward Control Chassis
45 = Forward Control Panel (Round Front)
Assembly Plant
A = Atlanta
B = Baltimore
F = Flint
J = Janesville
N = Norwood
P = Pontiac (GM Truck)
S = St. Louis
T = Tarrytown
Z = Fremont
1 = Oshawa, Ont., Can.
1969k10stepside is offline   Reply With Quote
Old 03-08-2007, 03:40 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That VIN decoder is for a chevy, GMC doesn't match up. Rod is a GMC VIN guru, all I really see there is a V-8 4X4 truck built in St luis
Old 03-08-2007, 06:22 PM   #4
ckoett
Is there a VIN decoder website for GMC's then?
Old 03-08-2007, 07:34 PM   #5
Rascal_one2001
Rascal_one2001's Avatar
I looked for a few hours when I bought a 71 gmc but no luck.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 03-08-2007, 07:47 PM   #6
Longhorn Man
Did you get an owner's manual with it? They have one in there.
Old 03-09-2007, 12:11 AM   #7
Rod
The Models simple to decode.
KE25934
K = 4x4
E= eight cyl
2 = 3/4 ton
59 = 54 inches, cab to rear axle
34 = wideside/fleetside box
KE234-S118668
As for the vin its fairly easy too
K= 4x4 conventional body
E= eight cyl
2 = 3/4 ton
34 = pickup box body
- = state code if applicable, otherwise it just dash, as in this case
S = St. Louis assembly plant
1 = 1971
18668 is the sequence number of the total vin
Rod is offline   Reply With Quote
