Old 03-08-2007, 02:43 PM   #1
NPilot1975
NPilot1975's Avatar
Brake Booster Question
I am looking at replacing my brake booster and would like to go with one that is smaller and preferably flush to the firewall. What I really want to know is can I run a 7" or 8" dual diaphram booster and get the same boost as my factory 11"? Does anyone make a bracket/push rod to replace the factory and allow the booster to be flush or at least closer to the firewall? If not does anyone know how to modify the factory one? Thanx for any help!
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 03-08-2007, 04:16 PM   #2
Orange
Licensed to Thrill!
Orange's Avatar
Re: Brake Booster Question
I think you have to shorten the factory rod, which isn't that big of a deal. I have seen it discussed.
I too have the same question about the booster though. I don't really like the small ones that make up for diameter by being two times as long...so we'll see what gets posted.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-08-2007, 05:20 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
We put a 8 inch on mine, it came with smaller brackets, but we had to lower to center hole on the firewall so the boot would fit through. We also shortened the push rod.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 03-08-2007, 06:32 PM   #4
zeeklu
These are the guy's I got my set up from. http://www.rightstuffdetailing.com/ The booster sits level and much closer to the firewall. Chris
zeeklu is offline   Reply With Quote
Old 03-08-2007, 08:46 PM   #5
NPilot1975
NPilot1975's Avatar
Jugernot-
Where did you get your booster from? Looks like CPP?
Old 03-08-2007, 09:47 PM   #6
jugernot
Life, Be In It.....
jugernot's Avatar
Originally Posted by NPilot1975 View Post
Jugernot-
I picked it up at the Good Guys swap met in Pleaston Ca. last fall. I purchased it there because it was cheaper then CPP. You could probably get the same one from CPP.
