adjustable part throttle on a qjet
is there a special procedure in which to set this for the qjets? my 70 c10 with a 305 gets 11mpg on the highway and i dont think thats normal lol. its got long tubes and a tow cam...thats it for engine mods.
![]() edit: trans/rear end:th350 with 3.73s Last edited by regal8r; 03-08-2007 at 05:05 PM. |
Re: adjustable part throttle on a qjet
up
Answer=3.73 gears you are running. MPG about normal for your set up.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
![]() Join Date: Dec 2006
I get 15.5 highway w/3.73s (but manual trans and a 350).Check your vac.advance.Put a timing light on it and suck on the timing adv. hose and watch for considerable advance.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 03-08-2007 at 06:41 PM. |
Make sure your timing, vacuum advance, float level, and idle mixture is set right. There are no other fuel adjustments except changing jets and metering rods. What size eng was your q jet originally calibrated for?
Q jets were also bad about leaking fuel internally from the main jet well plugs. If it hasn't been rebuilt recently, you need to rebuild it and seal those plugs with epoxy to prevent this problem. Also, a 305 is working a lot harder to pull 2 tons of truck against the wind than a bigger eng would be. My 69 had a stock 307 with a 2 bbl carb, and would get 8-10 mpg hwy, at best. I replaced it with a mildly built small block 400 and got 12-14. The 400 has more torque at 1/4 throttle than the 307 did wide open , so it can run 70 without even breathing hard.
"Negative people always seem to have a problem for every solution" |
#7 | |
You could probably gain a couple of mpg on your 305 by rebuilding the carb and making sure it is jetted properly for your application. A 350 and higher gears might get you in the 13-15 range. Or keep your 3:73 gears and put in an overdrive trans would be even better. If you can afford it, go with a late model fuel injected vortech 350 and overdrive. My 99 Yukon gets 18-20 hwy with 3:73 gears and 4l60E overdrive. There are a lot of these later model fuel injected vehicles in the junkyards you could swap every thing over from.
The biggest thing affecting gas mileage is the downward forces exerted by the right foot on the get louder pedal.
#9 | |
Saving 1 truck at a time!
Qjets came with hundreds of different primary side calibrations. You can check the primary part-throttle calibration with the "tip-in" procedure after the engine is fully warm. Set the idle screw to 2000-2200 rpm. Gently tip in the choke flap, don't close completely and kill the engine, but move it in until you see a 50-100 rpm increase. This means you are just on the lean side and perfect. If there is no increase or the rpms fall off you are rich. Pull a small vacuum hose from the carb and see if the rpms increase due to the additional air coming into the carb. If it does you are running a bit rich. Set your APT rods to give a slight rpm increase while "tipping-in" the choke plate (slightly lean). Final adjustments can be done by checking your plugs after a medium length freeway run. Compliments of Cliff Ruggles "How to Rebuild and Modify Rochester Quadrajet Carburetors".
Don't shoot the stinking messenger...LOL! BTW...those 3.73's are pretty deep...find some 3.08's.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 03-08-2007 at 08:51 PM. |
Just out of curiosity,did you verify the proper operation of the VACUUM ADVANCE unit on the distributer? If the diaphragm in it ruptures,or if the linkage gets jammed up the results will be lousy highway mileage.So easy to check,you might as well do so before talking about engine swaps,overdrive trans.or even re-tuning the carb.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#12 | |
Semi-Senior Member
Excellent post!!! regal8r, many have touched on your timing, and that is HUGE. Make sure the vacuum and MECHANICAL advance are both working. If you don't have a clue what the APT rods and these timing items are, tell us.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
#13 |
Here's an excellant website for tuning a q-jet http://www.corvetteclub.org.uk/files...une_a_qjet.pdf
#14 | |
I'm showing my age here, but back in the old days when I worked for Chevy dealers, we used the "propane enrichment method " which accomplished the same thing. We would richen the mixture slightly with propane and watch the rpm to tell if the carb was running rich or lean. We also used a 4 gas analyzer to fine tune things even further. Now all the engines have fuel injection, oxygen sensors, and computers that can adjust fuel mixture and ign timing on each individual cylinder several times per second. Carbs were "state of the art" in their day, but fuel injection is the only way to go for the best performance and economy.
#15 | |
Semi-Senior Member
stlookin is talking about the APT, which is the screw that adjust how far the metering rods go into the main jets.
#16 | |
#17 |
all this seems pretty complicated. how much would a shop charge me for tuning the carb?
#18 | |
Semi-Senior Member
You could ask at a NAPA parts store if there is anyone they know who is good with the carbs. Then ask the guy about adjusting the apt rods. You'll probably get a blank scare..... And yes, those are the metering rods. Also can be referred to as the 'power piston or valve". They have a spring that pulls them up when vacuum drops. So there are 2 things that effect where they are when cruising. The screw that sets the stop and the strength of the spring pushing the rods up. jacobs link is very good. Maybe a little hard to follow but try reading it a few times, it might help.
