Old 03-08-2007, 10:02 PM   #1
62 short step
62 short step's Avatar
Front axle
I just got a 10 bolt axle to replace my closed knuckle front axle on my 61 4x4. My ? is what do I need to look out for? Should this be a direct bolt in? Just trying to figure out what all I am going to need to do this swap. Any info is appreciated. Jeremy.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-08-2007, 10:14 PM   #2
msgross
msgross's Avatar
Re: Front axle
I'm doing this with a 68 and a dana 44 is the same ... not sure on yours.
I haven't seen any major issues yet, but i'm changing brake lines anyway and cut my u-bolts too...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-08-2007, 10:30 PM   #3
Re: Front axle
If you had drum brakes,you`ll need the rest of the disc system:master cyl/prop.valve.
Old 03-08-2007, 10:36 PM   #4
62 short step
Re: Front axle
I'm going to try to do mine this weekend, hopefully. Do you have a power brake booster, or are you going to run the disc brake without one?
1965 c-10
86 chevy c/k 20
Old 03-08-2007, 10:38 PM   #5
62 short step
Re: Front axle
Thats the answer I was looking for. Can I run the disc brakes with no power booster?
1965 c-10
86 chevy c/k 20
Old 03-08-2007, 11:29 PM   #6
msgross
msgross's Avatar
Re: Front axle
I believe so, the prop valve is the most important for the disc...needs to keep pressure on the disc at all times. Don't know if the MC is different though... I'm adding booster and MC from a 1 ton..
The Garage:
Old 03-09-2007, 08:23 AM   #7
Re: Front axle
Yes,I`ve seen 71/72s w/o power brakes from factory.It was still an option.
Old 03-09-2007, 09:15 AM   #8
62 short step
Re: Front axle
Thanks guys, I'm going to try it this weekend. I've been so busy with work I havn't had time to work on my truck. Its killing me because I love to work on it!!
1965 c-10
86 chevy c/k 20
Old 03-09-2007, 10:59 AM   #9
Re: Front axle
Looks like you swapped a bed since the last time I saw it.
Old 03-09-2007, 11:06 AM   #10
pumpkin
pumpkin's Avatar
Re: Front axle
Its actually the other way around. the drum brakes have a residual check valve that keeps a small amount of preasure in the system to help keep the seals in the wheel cylinders sealed. with disc-drum the check valve is only for the drum brakes, and there is a delay valve for the disc brakes to allow the drums to catch up. I have used a drum brake master on a disc setup and had it work well. the biggest thing with a disc brake master is the size of the resevoir, cuase as the brakes where the fluid level goes down.
pumpkin is offline   Reply With Quote
Old 03-09-2007, 11:49 AM   #11
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Front axle
I'm planning this swap soon so I just want to sit in on the conversation.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 03-09-2007, 02:07 PM   #12
1969 GMC
1969 GMC's Avatar
Re: Front axle
Hopefully in the summer I will be getting the D60 under mine. It's out of a '78 Dodge, so there are a couple more hangups than a GM axle. Spring spacing is like 1/2" off, and the yoke is totally wrong. Also, Dodges apparently used a single soft line going down to the axle, then a T-fitting with hardlines running along the axle tube to either side. I'll change that to the GM style.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-09-2007, 02:12 PM   #13
62 short step
Re: Front axle
Yea I changed to a fleet. I like the way they look on 60-66 trucks.
1965 c-10
86 chevy c/k 20
Old 03-09-2007, 02:14 PM   #14
62 short step
Re: Front axle
If I get to it this weekend I'll post some pics and and trouble I had. Hopefully will not have trouble, but you never know!!
1965 c-10
86 chevy c/k 20
Old 03-09-2007, 10:42 PM   #15
Re: Front axle
I agree,handsome truck there.
Old 03-10-2007, 12:36 AM   #16
62 short step
Re: Front axle
Thanks, I hope to paint it this summer too. Here are a few pics. My 4 year old likes to help also!!
1965 c-10
86 chevy c/k 20
Old 03-10-2007, 12:39 AM   #17
1969k10stepside
Re: Front axle
Got to love original old old 4x4s.And the shortbed factor make me like it even more.I cant blame ya for getting rid of the ol closed knuckle drum brakes,my 69 that is the same way is being converted to 1 ton so I wont have to worry much about the drums anymore
1969k10stepside is offline   Reply With Quote
Old 03-10-2007, 01:11 AM   #18
454_72_4X4
454_72_4X4's Avatar
Re: Front axle
You're close pumkin.
Actaully there is a residual pressure valve in both disc and drum brake systems.
In a drum brake setup it's function is the keep the brake shoe springs from drawing the shoes away from the drum. It usually holds about 10lbs of pressure.
In a disc brake system it holds about 2 lbs of pressure.
The big question is "where is this residual pressure valve located on different systems"? I've been trying half heartedly for quite some time to come up with a definate answer to this.
Are they always in the master cylinder, or in the proportioning valve, or both, or...?
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-10-2007, 08:42 AM   #19
62 short step
Re: Front axle
Yeah, I love the old 4x4s. I had a 63 short bed 4x4 a few years ago, sold it and regreted it. So I found my 61 from a board member last April in Wisconsin. Happy again!
1965 c-10
86 chevy c/k 20
Old 03-10-2007, 09:19 AM   #20
Re: Front axle
And,I have the tailgate for my "created from parts" 72-ish shortbed stepside GMC 4wd.
When I was living near Flagstaff,AZ around 1980,the owner of the Flag Carwash(service station/store,too)owned a black one and a white one,both Fleetsides...both gorgeous.They sat under the huge "RT 66-style" lighted sign.He had one set up with dune paddles.Ahhh...memories.
I still want one.The 60-62s are quite rare.Lookin`Gooooood.
