Edelbrock carb question
I'm running an Edelbrock 1406 with an electric choke that isnt hooked up. Is it possible to hook up the choke to work manually instead of electric?
2002 S10 ZR2 for the dirt. 1968 C10 shorty for the street. She said the truck would be the end of us. I still have the truck! |
Re: Edelbrock carb question
not from what ive read. you have to either have the electric one or you get the manual one cant have both from one carb. i took mine off all together lol
look into the Manual set up for the 1400 ser. Ed. carbs.
probly just unbolt the electric and bolt up the manual set up The OEM choke cable is short so plan on getting a aftermarket.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
For $22, Here's a divorced (no cable) choke kit. It adapts to a Performer manifold and carb.
http://store.summitracing.com/partde...5&autoview=sku
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
Alright, here's the deal, you know how to adjust the choke, right? Loosen the three screws around that plastic housing, and turn the black case to adjust the cold position of your choke. When your truck is cold, loosen those 3 screws, and turn that housing until the spring engages to the point that the choke is ALL the way open, tighten screws. Game over, put your wire to it and give it power, and ground the other side, and it won't open any more than that, because you have it all the way open when it's cold, so it won't open when its hot. That'll save you some cash too. Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s ![]() ![]() Last edited by bad72c10; 03-09-2007 at 10:05 PM. |
#6 | ||
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
Ha, oops, I guess you still want a choke,huh? Well, I guess mine won't work if you want an actual choke, but if you live where it's warm, you don't need one anyway. Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s ![]() ![]() |
