Old 03-09-2007, 12:48 AM   #1
herb101
Used Register
herb101's Avatar
TBI or 700R?
Which single mod (TBI conversion or 700R4 swap) would give the best mileage improvement?
For the requisite background, the truck is a 71 K5 with 350, Edlebrook carb, TH350 and 3.73 gears, running 35's. I get about 8-9 mpg now and the 30% gas price hike has me thinking...
I have the ability to perform either swap, so install costs won't be a factor. I'd like to do both eventually, but which should be first?
Thanks,
Herb
herb101 is offline   Reply With Quote
Old 03-09-2007, 01:07 AM   #2
metalmassfab
Junior Member
metalmassfab's Avatar
Re: TBI or 700R?
I say hands down, no contest....700R4. I was getting that same 8-9 mpg with the same engine in my C-20 with a TH 400, 4.10 gears and 31" tires. She screamed at around 3200+ on the highway. The 700R4 dropped the rpm down to under 2400, and the mpg jumped to 14. A while later I installed a 510 hp 383 (pic is for proof...) and I got just over 16 mpg with that combo. Sounds like BS, I know! But a well worn 320 hp 350 still wastes more fuel than a well tuned torque monster. Of course when the pedal hit the metal on the 383, all that went right out the window...go for the tranny, its the best thing you can do for your rig!
Ryan
Metal Massacre Fabrication
New Projects:
-New radiator core supports, steel and stainless
-Aluminum radiators
-Aluminum dual electric fan shrouds
'69 C-20 Custom
'69 Nova...BIG BBC soon
'72 3-door 'Burb...in a few
'94 K2500 454 'Burb
metalmassfab is offline   Reply With Quote
Old 03-09-2007, 02:06 AM   #3
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: TBI or 700R?
Atleast on the more power part. I've seen it first hand on a friends truck he was selling. He wanted to keep his well built higher HP engine so he took it out and we put together a new well rebuilt stoker and his gas milage went ta s%$. The harder ya have to run them the more gas your gonna use.....hmmmm....well I guess that answers your question too working the engine less with the overdrive would kinda be the same but different right?? Well thats my point. RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-09-2007, 02:18 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Re: TBI or 700R?
Overdrive is more beneficial to fuel economy than EFI. EFI just multiplies the effect by more precise metering of fuel at lower rpms...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-09-2007, 02:47 PM   #5
Chris27
Blazerless
Chris27's Avatar
Re: TBI or 700R?
Do the overdrive first. If you had a Q-jet on that thing you wouldn't notice much difference between that and TBI for gas mileage.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 03-10-2007, 11:49 PM   #6
chiggly626
Re: TBI or 700R?
With your current gear ratio and tire size I would go for the TBI. You will need at least 4:11's to use OD with 35's.
chiggly626 is offline   Reply With Quote
Old 03-11-2007, 02:08 PM   #7
metalmassfab
Junior Member
Re: TBI or 700R?
Another note: TBI is not much better, if any, than a carb of the right size and decent tune up. TBI squirts fuel in the same manner as a carb. For the serious mpg gains, tuning, and power, a multiport fuel injection system unit like the Holley MPI Commander 950, Edelbrock Pro-Flo, Accel DFI, Fast unit...blah blah...These have the injectors placed as close to the cylinder as possible. TBI swaps are pretty popular, and I am not just talking smack about them; I just dont think its a worthwhile swap, especially if you will be adding performance upgrades later. TBI units just dont handle performance applications well. Like Holleys $900 2BBL digital TBI unit...it'll handle up to 275 hp...!! Three times the price of a carb, and no better performace, marginal economy. I do understand that a TBI is probly better on a stock type engine on a 4X4 that sees a lot of climbing at angles that can flood a non-prepared carb, so there is a plus side.
The 700R4 will increase your mileage, and with its deeper initial gear set, your acceleration will be vastly improved over your current tranny, tire size, and gear ratio. This is the best thing for 4X4's and heavier vehicles...and your highway cruising rpm will be down around 2000 at 70 mph or so. you wont be disappointed!
Ryan
New Projects:
-Aluminum radiators
'69 C-20 Custom
'94 K2500 454 'Burb
Old 03-11-2007, 03:01 PM   #8
herb101
Used Register
herb101's Avatar
Re: TBI or 700R?
Thanks for the replies so far. I'd really like to go with a TPI setup, for the performance and looks, but they just don't exist in yards around here & the prices get pretty insane on eBay - maybe someday.
On the 700r4 topic - I have seen writeup for the swap, but only on the 2wd trucks. What is a good doner for a 4x4 swap? I have the TH350 & NP205 setup, so the tailstock pattern and spline counts are in good shape. What years would be the best for durability? I have heard of folks burning up multiple 700s, but is this due to improper setup or weak internals? I would go with the proper TV linkage setup. with teh swap.
Thanks,
Herb
Old 03-11-2007, 03:18 PM   #9
ffrider
Re: TBI or 700R?
I know this is basic but can someone explain gearing to me what does 3.73 4.11 etc. gearing mean?
ffrider is offline   Reply With Quote
Old 03-11-2007, 03:51 PM   #10
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Re: TBI or 700R?
Thanks,
Herb
I have talked the tranny guy that use to build my drag race autos, , about this swap. He also happens to run a 700R4 in his 1975 Blazer with 35's (3:73's) and a 454 in front of it. This is the information he gave me. You want a 4X4 88'-92' 700R4 because these have the thicker case on them. The 700R4 case is longer then the Turbo 350, so you will need to move the T-case back about 2 inches, but on a lifted rig, that is not a bad thing. The output shaft in the needs to be replaced with a longer one that can be bought for about $150, but there is no no need for any other adapters . When he rebuilds them, he puts extra clutch packs in and uses the "high energy" factory stuff. His tranny had been in his Blazer for 7 years without a problem, so I think he may know what he is doing. I think that most of my information is right, but other please correct me if I am wrong.
ABLAZN is offline   Reply With Quote
Old 03-11-2007, 04:40 PM   #11
herb101
Used Register
herb101's Avatar
Re: TBI or 700R?
Awesome stuff! Thanks!
ffrider - on the gear thing...the gear ratio is commonly expressed as a single number like 3.73 or 4.11, but it actually means a ratio of 3.73 pinion rotations to 1 ring gear rotation. What this means is that for the wheel to complete 1 full turn, the driveshaft turns 3.73 times. Assuming no overdrive, the final gear ratio in the transmission is 1:1, so 3000 engine RPM = 3000 driveshaft RPM = 802.3 axle RPM with a 3.73 gearset (729.9 axle RPM with a 4.11 gearset).
To take it one step further and expalin why tire size affects your 'effective gearing' and speedometer calibration, consider the tire circumference. A 35" tall tire would travel approximately 110 inches in one rotation, while a 30" tall tire would only go about 92-1/4". That means that the taller tire rotates 576 times per mile, while the short one has to turn about 687 times. Since your speedo is triggered off dirveshaft RPM, you can see where the difference occurs.
When you hear people talk about going to a "lower gear" or a "deeper gear" for more low end grunt, it means a lower ratio or a higher "big" number because 1 / 3.73 is a larger number than 1 / 4.11. A "taller gear" means a smaller "big" number for lower highway engine RPMs.
Hope that helps,
Herb
Old 03-11-2007, 08:45 PM   #12
pound41
Re: TBI or 700R?
Check out Bowtie Overdrives web site they have everything you need. Even built trannies for a 4x4 I am thinking about getting one from them. Only bad thing for me they are on the west coast. Not sure about shipping Their stuff is highly recommended by some of the other posts I had read
pound41 is offline   Reply With Quote
Old 03-13-2007, 08:42 PM   #13
Jason915
Re: TBI or 700R?
I did the TBI on my K5 its a mild build, 355 w/ L98 Iron heads, CPU friendly CompCam, headers, stock GM TBI intake & TB, TBI spacer and it's chipped. With a TH350 3.73's and 33's I am in the 10MPG Club so really the TBI is not the best MPG set up as far as EFI's go becasue my truck with a more powerfull engine and 4BBL gets the same or slightly better. I do love the TBI for 4wheeling it's good for that but not for MPG. I would imagine that a 700R4 would help.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 03-14-2007, 04:00 PM   #14
Scrubby
Check out GMTrucks.org
Re: TBI or 700R?
I recommend pricing either swap and then doing a cost analysis on it to see if it is worth it for you.
If a 700R4 swap runs you $2000 and gets you 18 mpg (gaining 10 mpg), at $3/gal gas, you have to drive almost 12,000 miles to pay off the swap. If your blazer is a daily driver, that might be 6 months of driving. For my blazer, that might be 5 years of driving. Not worth it to me.
Just something to think about. Now, if you just want to do the swap because it is cool, then go for it!
Scrubby is offline   Reply With Quote
Old 03-14-2007, 05:59 PM   #15
onetonk5
Cereal Killer
onetonk5's Avatar
Re: TBI or 700R?
I have never done/worried about a cost analysis for anything i have ever done to anything i have ever owned. Figure if its worth my time to do it's worh it to me. A 700r4 not only will make your rig more fuel efficient but it will be more enjoyable to drive. Deeper first gear and overdrive is always a plus.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 03-22-2007, 10:14 PM   #16
herb101
Used Register
herb101's Avatar
Re: TBI or 700R?
What would be a good price to expect to pay for a 700R4?
I have a line on one from an 88 4x4 burb, rebuilt 42K ago, with convertor.
Thanks,
Herb
Old 03-23-2007, 09:39 AM   #17
BUDDY
Global warming is a myth
BUDDY's Avatar
Talking Re: TBI or 700R?
Thanks,
Herb
If you can get that one on EBAY for 400 or less I say go for it.
However, if you double that price you 'll get one that's been completely rebuilt with a warranty of some kind. You could go to autozone or some other local place & get one outright that way as well. Or you could go to the JY, pick one out, & have it rebuilt by the most highly recommended shop around you. If you do it that way it doesn't matter if it's 2WD, 4WD, just have it done the way you want it. Oh the possibilties!!
I think you can pay as little as 800 for a chain store rebuild or as much as you want for a full performance setup. Just remember all the other ancillary things, TV-cable bracket, TC, cooler, etc., etc. Check this site for some GREAT info. I got that link from here.
Good luck,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
Old 03-23-2007, 10:33 AM   #18
martinkh
Re: TBI or 700R?
I am thinking about this for the future also. It seems the weak link on the 700r4 is the lockup. I was thinking of 2 solutions:
Go with non-lockup converter. More heat, but little chance of breaking the tranny this way.
Go with electric controlled lockup, with pushbutton on, only works when a sensor says it is in overdrive/4th gear, and have it like cruise control so that tapping the brake disengages it. But is there an electrical or mechanical output that would tell you when it is in 4th gear?
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift.
'77 400sbc, '82 axles, d60front, 14bolt rear.
Probably some 285/75/16 Toyo m/t's on my stock rims coming up.
martinkh is offline   Reply With Quote
Old 03-23-2007, 02:09 PM   #19
Chris27
Blazerless
Chris27's Avatar
Re: TBI or 700R?
That's kinda how the 700R4 lockup converter in my car works. There are four wires in the lockup harness. You only need two. One is ground, the other power to the lock up in 4th gear. The power wire goes through a brake light switch, to a vacuum switch, and down to the converter. The vacuum switch unlocks the converter during low vacuum conditions (full throttle). Brake switch unlocks converter when brakes are applied. After I get my car out of storage I can check what wires are for what. By the way that "weak link" lockup converter is surviving just fine behind 479HP & 472lbs.ft. of torque. Biggest issue is TV cable adjustment, get that right and it will last a long time.
The 700R4 lockup in my K5 is controlled by the ECM. It locks up in 3rd & 4th gear. Has brake switch, but uses VSS (vehicle speed sensor) instead of vacuum. This one uses all 4 wires on the tranny.
Old 03-23-2007, 09:29 PM   #20
herb101
Used Register
herb101's Avatar
Re: TBI or 700R?
Well - I lost the one I had an eBay line on in the last 14 seconds. I am really beginning to HATE eBay. Now I can't even see the name of the person who sniped to be able to put the proper voodoo mojo on them - friken eBay
Herb
At least I made him pay and extra $60 over what he would have stolen it from me for....
Last edited by herb101; 03-23-2007 at 09:32 PM. Reason: getting an extra bit of a dig in
Old 03-25-2007, 09:30 AM   #21
martinkh
Re: TBI or 700R?
If you go all electric, can't you bypass the tv cable?
Old 03-26-2007, 09:33 AM   #22
Chris27
Blazerless
Chris27's Avatar
Re: TBI or 700R?
You still need a TV cable, unless you use a 4L60E. Those are the electronically controlled version of the 700R4. I think the 4L60E's are '93-up. The TV cable has nothing to do with converter lock-up.
Old 03-26-2007, 12:03 PM   #23
martinkh
Re: TBI or 700R?
OK, what does the cable do? Is it needed with a non-lockup converter?
Old 03-26-2007, 01:50 PM   #24
Chris27
Blazerless
Chris27's Avatar
Re: TBI or 700R?
TV cable controls shift points, line pressure, shift firmness, and kickdown. TV cable is still needed with non-lockup converter.
