Old 03-09-2007, 02:53 AM   #1
combustion
horse power
in a rough estimate,, how many horses would i be putting out? i have a gen 5 454 with a performer 2-0 mani and a 750 carb from addie as well. i have the stock cam and thats it. i just wanted to know how many horses would i be putting out around. thanx a lort. here is a pic just for the $hit and giggles.
combustion is offline   Reply With Quote
Old 03-09-2007, 03:41 AM   #2
bskylerj
bskylerj's Avatar
Re: horse power
I would guess 350 to 375hp. Just my guess.
bskylerj is offline   Reply With Quote
Old 03-09-2007, 09:15 PM   #3
mnunn454
mnunn454's Avatar
Re: horse power
It depends a lot on the compression ratio. I'd guess that with the Gen 5 454 you're around 9.0:1 or less in C/R. If the exhaust is stock manifold duals, then I'd agree, probably not over 375 HP. If it's got the peanut port heads it'd probably be 350 HP or less, (which still isn't bad, but could be FAR better with a decent set of heads and a decent compression ratio).
BTW, good choice on the carb and manifold.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 03-11-2007, 04:36 PM   #4
rust!!whatrust?
rust!!whatrust?'s Avatar
Re: horse power
I would certainly check out my head casting numbers. That could say alot.
Don't touch the Rust. Punk
rust!!whatrust? is offline   Reply With Quote
Old 03-11-2007, 10:36 PM   #5
metalmassfab
Junior Member
metalmassfab's Avatar
Re: horse power
The 454 in my '94 'burb has a whopping 230 hp, and a massive, toothpick-pulling 385 lb-ft of torque from the factory. Its kinda sad, the 383 in my '69 C-20 has near 2.2 TIMES the hp...and gets twice the mpg...
Ryan
Metal Massacre Fabrication
New Projects:
-New radiator core supports, steel and stainless
-Aluminum radiators
-Aluminum dual electric fan shrouds
'69 C-20 Custom
'69 Nova...BIG BBC soon
'72 3-door 'Burb...in a few
'94 K2500 454 'Burb
metalmassfab is offline   Reply With Quote
