Old 09-01-2002, 12:39 AM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
good a/c temp
what are you guys running for temp on the air comming in from your vent?? those of you with a/c that is. whats normal?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-01-2002, 12:24 PM   #2
mtdave2
mtdave2's Avatar
noone knows?
69 k10 Suburban
Old 09-01-2002, 01:45 PM   #3
dmec
dmec's Avatar
mine is 48 deg. depends on outside temp. when over 100 deg vent is around 50 to 52 deg. im using an accumulator system with r134. used all original a/c system but replaced evaporator with a later model truck evaporator set up for cycling cluth system.
dmec is offline   Reply With Quote
Old 09-01-2002, 03:21 PM   #4
ThreeQuarter
ThreeQuarter's Avatar
Dave, a really good temp to have coming out of your vents is in the low-mid forties. I've achieved that on late-model pickups, but don't know how easy it would be to get that number on ours. And yeah, it'll go up considerably if it's really hot outside.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 09-01-2002, 08:53 PM   #5
mx jim
The best way to tell if you are getting a good efficient system is when the air coming out of the register is 20-25 degrees colder then the air recirculating back to the evaporator. This will reach a maximum temp that will be about 45-50 degree supply air temp. At a suction pressure of 32 lbs the gas temp is at about 32 degrees and the losss through the coil will get you about 42 degree air. Good luck these are just rough figures. Ed ke6bnl
mxjim 1970 chevy 4x4, 400 small block, 4" pro comp lift, with 35s.
mx jim is offline   Reply With Quote
Old 09-01-2002, 11:39 PM   #6
billogna
billogna's Avatar
Mine is 45 deg @2000 rpm, and about 53 @idle, with about 95 deg outside temp. I'm using all original parts except for 134A and ditching the POA valve in favor a clutch cycling switch version from Old Air Products.
'69 Chev Cust/10 swb, 350/700R4, 5"/6"
'70 Chev C10 swb, 67 front, 454/700r4, 4"/5"
'73 Chev stepper, 350/3 spd
'84 Chev K20 350/4 spd
'91 GMC 1500 Suburban 4x4, 350/700R4
billogna is offline   Reply With Quote
