Old 03-09-2007, 12:32 PM   #1
dh81k30
Junior Member
dh81k30's Avatar
Question Rear spring
Hi folks,
Thought I would ask here first.
My '86 C10 swb has started driving a bit erratically lately. I am fairly certain that the front end is in good shape. It has only been about two months since it had lower ball joints installed and an alignment. The other day I had the opportunity to get it on a lift to look for loose parts. The only thing I found is that the right side of the rear axle appears to be sliding back and forth on the rear spring about 3/4 inch. I think that there is supposed to be a locating pin to prevent this sliding.
Does anyone know what I need to fix this problem? Can I fix it or will I need to take it to a spring shop?
Any help will be appreciated.
Have fun, Don
dh81k30 is offline   Reply With Quote
Old 03-09-2007, 12:39 PM   #2
Texas Lefty
Re: Rear spring
The axle should not have any play on the spring. There is a locating pin on the axle housing and they do break off sometimes.Loosen the U-bolts carefully I would recomend some kind of lubicant like wd-40 before loosening.Then raise the truck off of the axle and look for that pin.If it is not there you can have the saddle welded directly to the axle housing.
Texas Lefty is offline   Reply With Quote
Old 03-09-2007, 05:36 PM   #3
Zilverado
Zilverado's Avatar
Re: Rear spring
I agree - that axle should not be moving around at all.
As for getting the u-bolts off, you might need something a little stronger than WD-40 to break the corrosion of 20+ years and get the nuts off. I did something similar a number of years ago, and ended up using my "blue-tipped" wrench to cut the bolts. Of course, you could always use a angle grinder as well. Just be carefull if you use a distructive method, because the u-bolts are typically in tension and come apart with a little energy - nothing too scary, just something to keep in mind. If you CAN back off the nuts, this is not an issue.
As for fixing the broken pin, I don't really know what to suggest. Never done that before. I assume someone else will chime in though.
Zilverado is offline   Reply With Quote
Old 03-10-2007, 09:46 PM   #4
dh81k30
Junior Member
dh81k30's Avatar
Re: Rear spring
Thanks guys,
I appreciate the help.
Have fun, Don
