Old 03-09-2007, 06:49 PM   #1
slepysal
slepysal's Avatar
After Market Gas Gauge
Will an after market gas gauge that is rated as folllows:
Empty 240 ohms
1/2 130 ohms
full 33 ohms
work with a stock sender? If not what can be done with the feed line on the original one? The after market one has none. HELP !!!
slepysal is offline   Reply With Quote
Old 03-09-2007, 10:54 PM   #2
slepysal
slepysal's Avatar
Re: After Market Gas Gauge
any one ?
Old 03-09-2007, 11:15 PM   #3
NF65Fleetside
NF65Fleetside's Avatar
Im kind of wondering the same thing but I think the Autometer ones come with a new sender as well.
NF65Fleetside is offline   Reply With Quote
Old 03-10-2007, 04:48 PM   #4
larry may
Reckon they have to be amatched set. As I was going to purchase an in tank float ascending unit. Clerk in formed me that a fuel gage is required for the unit to read correctly that is recommende by the manufacture of the unit.....my .02%
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 03-12-2007, 12:41 AM   #5
Captainfab
60-66 Nut
That gauge will not work with your stock sender. Up until around 65 the stock sender operates at IIRC 0-30 ohms, then around 65 the senders changed to 0-90 ohms. You're probably going to have to go with an aftermarket sender to match your gauge. Not sure what to say about the fuel line not knowing if you have an original tank or not.
Old 03-12-2007, 04:33 AM   #6
slepysal
slepysal's Avatar
I have the sendre to match the gauge, but it has no fuel line,and yes still have the stock tank.
Old 03-12-2007, 03:48 PM   #7
Captainfab
60-66 Nut
There are a couple of ways to go about it. The easiest would be to locate your new sender in another spot and leave the original there so you can utilize the fuel pickup tube. The other way would be to remove the pickup tube from the original and drill a hole and solder it into the new one. You could also try and remove the sender itself from the original assembly and replace it with the the new aftermarket piece. That way you would still have the original mounting plate with the pickup tube in it, and the new sender attached to it. I hope that was easy enough to understand. If you still have trouble post up some pics, and then it may be easier to figure out.
Old 03-12-2007, 10:14 PM   #8
slepysal
slepysal's Avatar
Thanks for all the grat ideas,. I found an autometer pn 1318 white face gauge for 32.00 from sunnit. so insteat of pulling my sender i'll go that route thanks agiain oh anf great ideas Cpt.Fab
