Old 03-09-2007, 08:46 PM   #1
76bonanza
76bonanza's Avatar
ohm help
I am electical handicaped if I want to check if a wire is good from one end to the other I can use my multimeter on ohms correct? So I set it on 200 and touch both ends it buzzes and reads .3 is that good?
Thanks for your help.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-09-2007, 08:57 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: ohm help
That's good
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 03-09-2007, 09:06 PM   #3
BustedTruck
BustedTruck's Avatar
Re: ohm help
Thats good. Try touching your leads together it will probably read .3 ohms also
BustedTruck is offline   Reply With Quote
Old 03-09-2007, 09:22 PM   #4
regal8r
Re: ohm help
if u want to get a better reading of a wire and its conductivity, put your meter in the DC voltage setting and put each lead on each side of the wire with current flowing through, if it gives u more than .2v then u need to replace it. this is referred to as a voltage drop test and MUCH more effective than a resistance test.
regal8r is offline   Reply With Quote
Old 03-09-2007, 09:35 PM   #5
76bonanza
76bonanza's Avatar
Re: ohm help
My meter does not have that setting I dont think not very high dollar.
1968 c10
lowered 3" 4"
Old 03-09-2007, 09:51 PM   #6
regal8r
Re: ohm help
can u take a pic of it?
Old 03-09-2007, 09:56 PM   #7
regal8r
Re: ohm help
look for settings that say dcv or acv
Old 03-09-2007, 11:56 PM   #8
68C15
blood type; Retumbo
68C15's Avatar
Re: ohm help
general rule of thumb; when doing a voltage drop test you should not have more than .2V drop for each connection. (this is why crimp connectors are bad and soldering is best.)
68C15 is offline   Reply With Quote
Old 03-10-2007, 12:14 AM   #9
regal8r
Re: ohm help
and on the crimp connectors/butt splices, as long as they are not exposed to the elements, they would be find to use...other wise just use good ol' heatshrink
Old 03-10-2007, 10:13 AM   #10
76bonanza
76bonanza's Avatar
Re: ohm help
no niether of those settings.
1968 c10
lowered 3" 4"
Old 03-10-2007, 04:49 PM   #11
regal8r
Re: ohm help
can u take a pic of it and post it up on here?
