Old 03-09-2007, 09:54 PM   #1
cajundragger
efi tank
what tank are you guys running in a 47-54 that supports efi?...more specifically a 500 horse ls6?
No limit has one but they want $440 plus pump plus sending unit....
any ideas?
cajundragger is offline   Reply With Quote
Old 03-10-2007, 07:32 PM   #2
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: efi tank
I'm going to run this one from Summit Racing it cost 249.00. Part number SUM-291220-S. I will fab someway to mount it once I get it.
Kabwe is offline   Reply With Quote
Old 03-11-2007, 03:54 AM   #3
Daniel U
Daniel U's Avatar
Re: efi tank
I had a custom one built to fit (20+gal.) with a stock TPI fuel pump. If you go the custom route, use the fuel pump that normally feeds the motor. Shouldn't go wrong there, right?
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 03-11-2007, 10:20 PM   #4
cajundragger
Re: efi tank
well im hoping for 100 hp over stock....so Im not sure how that will work....ugh
Old 03-19-2007, 11:02 AM   #5
Detroit3100
Re: efi tank
there is a cheaper one from summit, $169 ish, it is plastic.
Detroit3100 is offline   Reply With Quote
Old 03-19-2007, 12:40 PM   #6
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: efi tank
what kind of pump are you using? in-tank or external? if external, the only thing you would need to do is drill a hole for the return line.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
