Old 03-09-2007, 10:11 PM   #1
RicksTrucks
RicksTrucks's Avatar
Identify this rear axle for me
Not sure what it is
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 03-09-2007, 10:13 PM   #2
1969k10stepside
Re: Identify this rear axle for me
14 bolt,maybe semi or full floater.Popular among offroaders.Probably has gov-lock in it
1969k10stepside is offline   Reply With Quote
Old 03-09-2007, 10:14 PM   #3
JAKES 68GMC
Aluminum slot wheels rule...
Looks like a 14 bolt to me.
JAKES 68GMC is offline   Reply With Quote
Old 03-09-2007, 10:25 PM   #4
kwmech
upside down 14 bolt full float
Old 03-09-2007, 11:06 PM   #5
tlob-41 a s`ti,eerga I
Old 03-09-2007, 11:17 PM   #6
RicksTrucks
what were they originally on?
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 03-09-2007, 11:18 PM   #7
1969k10stepside
The 3/4 tons from the 73-????.They were in the 4x4s on the back,dont know about the 2wds
Old 03-09-2007, 11:22 PM   #8
Crank
Crank's Avatar
3/4 ton stuff... Its a Corp. 14 bolt from '73+, it's a full floater too. Very GOOD rearend if you ask me, popular to get parts for, cheap to buy, cuz they are everywhere, cheap to build... Gov locks suck if you plan on building it for a 4x4... Pop the diff cover and see what kinda gears she's got. Oh yea, the mounts will work on a half ton, like if you plan on replacing a 10 bolt or 12, that 14 bolt should bolt right into its spot...perches are the same width. You can disc brake them for pretty cheap too.
Brandon
Crank is offline   Reply With Quote
Old 03-10-2007, 12:11 AM   #9
RicksTrucks
Not that familiar with rear axle terminology. What is a full floater? When would you use it - would it be if the gear ratio is better than your 12 bolt? Is there a way to make the gov lock better?
I have one of these laying around and was just wondering what it could be used for or should I just sell it. Thanks
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 03-10-2007, 12:17 AM   #10
1969k10stepside
Full floaters are desirable because you can break a axle shaft and your wheel wont fall off,you can stilll drive home,assuming you have another axle turning the wheels.Thats why the offroaders want them.Gov-lock is junk,no way to improve IMO,replace it with a detroit locker or something similar.Semi Floaters are just junk,you break a axle and bye bye goes the wheel and tire.
