03-09-2007, 10:49 PM | #1 |
700r4 TV Cable
Okay guys, I need some help on the TV setup for the 700r4, I have an Edelbrock 1406 carb, and I don't want to spring $106 for the BTO kit for the carb. What did y'all do? Also, is the lockup wiring from BTO worth the $70 or does someone else make a similar kit for this, with a little more budget minded price tag? Thanks, Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s |
03-09-2007, 10:50 PM | #2 |
its all about the +6 inches
Re: 700r4 TV Cable
I'm the cheapest b@stard you'll meet, and that's the o nly way I would go in a non stock set up.
03-09-2007, 10:53 PM | #3 |
Re: 700r4 TV Cable
Man, you are QUICK! Well, if I can get around the mill I have at school, maybe I can make one up, who knows.
03-10-2007, 01:41 AM | #4 |
Re: 700r4 TV Cable
I don't recall the prices off the top of my head but TCI and B&M make lock up kits also.
Don't touch the Rust. Punk |
03-10-2007, 03:04 AM | #5 |
Re: 700r4 TV Cable
You need to buy the spring that will adjust your cable to the shuttle valve in your trans. You can try to compensate the adjustment but it just isn't the same. Read about the TP adjustment, BTO has a real good overview. I have burn't 2 700's already. I used a double switch on my brake switch one open/one closed and went thru a vacuum switch to a junkyard harness. Worked well for about 5 years. The brake switch went out and I just use a toggle on the dash. My 2 cents
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2. |
