Old 03-10-2007, 12:22 AM   #1
skokie
skokie's Avatar
How much coolant?
How much coolant does a 350 take? How much does the 3 core raidator take? When I pulled out my 350 I drained all of the fluid since it was dirty. Whats the best way to get a 50/50 mix?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 03-10-2007, 12:45 AM   #2
regal8r
Re: How much coolant?
run hosewater through engine until all thats coming out is water find the coolant capacity of entire cooling system, then open the radiator petcock and drain allt he water divide capacity by 2 and fill with pure antifreeze, then top off with JUST water. voila....PERFECT 50/50 mix
sorry i cant help u with the coolant capacity spec
regal8r is offline   Reply With Quote
Old 03-10-2007, 01:10 AM   #3
brak
brak's Avatar
I always dump the first jug into the radiator, fill the now empty jug with water, dump it into the radiator...
now you can pour half of your second jug into the empty first jug, fill both with water, and you have two jugs 50/50.
repeat the last step until the engine is full, put the leftover wherever you prefer to store your coolant.
Don't forget to remove the thermostat and fill the engine, but be carefull as it fills fast
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 03-10-2007, 11:32 AM   #4
cooters
the whole system should take between 3 and 4 gallons of mix. Remember to remove the block drains if you are flushing the system
cooters is offline   Reply With Quote
