Old 03-10-2007, 03:42 AM   #1
zeitlerusmc
zeitlerusmc's Avatar
answer my question right now cuz I need to know!!!!
Some of my buddys are aguing with me that there is such thing as a 350 "big block" I say no but they claim ther is a 350 big block, unless you but a smaller crank in a big block there is no way you can have a big block 350 and who would put a smaller crank in a big block, so am I right or are they right is there such thing as a big block 350 in a chevy plat form?????????????????
zeitlerusmc is offline   Reply With Quote
Old 03-10-2007, 07:11 AM   #2
larry may
Re: answer my question right now cuz I need to know!!!!
Some of these wizzards on here make 350 cid into 383 ,396, with unbeleivable HP. Read some of the threads in the Engine forum. Search around on the 67-72 forum . There are some unbelievable built engines .Especially about the 400 cid. Your friends may be correct in what they are trying to tell you.Good Luck...
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 03-10-2007, 08:36 AM   #3
62 short step
62 short step's Avatar
I have heard that pontiacs 350 was a big block, I've seen one and its bigger than chevys 350. Not 100 % positive.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-10-2007, 11:38 AM   #4
Lgriffin
There is a 366 ci BB. I'm using the pistons in my 292 six.
Larry
Lgriffin is offline   Reply With Quote
Old 03-10-2007, 11:53 AM   #5
19GMC63
19GMC63's Avatar
there was 348 cid BB used in the early 60's, late 50's in big trucks, and even the bigger passenger cars. Its considered a 5.7L, so that might be the confusion.
19GMC63 is offline   Reply With Quote
Old 03-11-2007, 05:48 PM   #6
PushnFords
How to classify a "big" or a "small" block is a big debate with Ford guys. With a Ford, a 289, 302, 351 Windsor, and 351 Cleveland all use the same bell housing pattern. A 351 Modified, 400, 429, and 460 all use another bell housing bolt pattern. Seems simple but then a 351C, 351M, and 400 all use the same heads! With Fords they usually classify the 289 bell housing as a "small block" and the 460 style is a "big block". With Chevys a 283, 305, and 350 is usually a "small block" and larger cubes are "big blocks". Except for the 400 small block....
Derek
PushnFords is offline   Reply With Quote
Old 03-11-2007, 07:00 PM   #7
poncho_villa
poncho_villa's Avatar
Check out this link;
http://www.mortec.com/borstrok.htm
It should eliminate the confusion. The entire site makes for interesting reading.
poncho_villa is offline   Reply With Quote
Old 03-11-2007, 07:24 PM   #8
Billla
Billla's Avatar
this is the only thing that's close if we're talking Mark IV and beyond BBCs. Small bore, tall-deck - 3.935 bore x 3.76 stroke.
Billla is offline   Reply With Quote
Old 03-11-2007, 08:32 PM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
Best way to prove them wrong is to get the casting number off the block and look it up at Mortec. The site also tells you where to look for the numbers. A true 350 is a small block. You can also do a visual comparison. The small block heads are visibly smaller, since the bore spacing is smaller.
One thing I've learned is to never say never, just prove them wrong. But in most cases, they won't want to listen.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-11-2007, 09:25 PM   #10
cst70rocket
the pontiacs are neither big or small block, they are all the same size. There is no 350 big block period. As close as you can get is a ford 352, and it's not a true bb, it's considered an FE series. The 348 is a w headed engine, and is neither big or small. Tell them they are full of poop.
cst70rocket is offline   Reply With Quote
Old 03-18-2007, 08:32 PM   #11
Bryan59EC
Bryan59EC's Avatar
with the introduction of the 348 in 1958----it had to be a big block.
was much bigger than the 283.
with the introduction of the 'mystery motor' in 65----we got the BBC as we know it today.
Bryan
Bryan59EC is offline   Reply With Quote
