Rottenwood Garage Member
Changing 4x4 Blazer to 2x4......what do you recomend?
I have a 1972 Blazer that is in good running condition but needs a good bit of work otherwise. I have not decided 100% if I am going to do a small lift and some 35's or turn it into a topless slammed driver for my daughter.
I know the wheell base is different (shorter) than the trucks of that vintage. I have several rolling 2x4 frames so the components will not be a problem. What is the easiest, quickest or BEST way to turn this thing into a 2 wheel drive? Thanks Last edited by 72freak; 03-10-2007 at 08:10 AM. |
The LuvShack Garage
Re: Changing 4x4 Blazer to 2x4......what do you recomend?
Fastest way is to axle flip the rear and bolt in a 2wd front crossmember
![]() But if it was me .......................................................................... I'd want trailing arms in rear (You can get everything of a coil spring truck) You would still need the front crossmember (Again all from that same truck) And lots of lil odds and ends (There are several threads on this just search)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
I bet you could take the pickup suspension and "slip"*it under there.
*I know,slight understatement ![]()
i recommend that you don't do it. j/k. to each his own...but what a waste, IMO.
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon |
