Old 03-10-2007, 04:57 PM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
What does it mean when.....?
One of my exhaust pipes has a lot more air blowing through it than the other side? My truck has felt like it was lacking power a little before I tore it apart. I'm in the middle of re-doing the chassis, I cut the mufflers out about a month ago, the bed is off it, and it is up on jackstands while I finish my step-notches out back. Today I started it up just to keep the engine lubed and I put my hand behind each pipe. Noticed that the passenger side has a lot more exhaust coming thru than the driver side. Why would this happen? About 2 months before I started tearing it down I did a compression test and everything was within 10psi so I'm totally baffled.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 03-10-2007, 05:07 PM   #2
regal8r
Re: What does it mean when.....?
do u have a crossover (x or h pipe)??
regal8r is offline   Reply With Quote
Old 03-10-2007, 05:11 PM   #3
67Fleet
67Fleet's Avatar
nope, they are running straight from the stock ramhorn manifolds.
-Bret
Old 03-10-2007, 05:13 PM   #4
regal8r
thats why. weld in an X pipe (for hp) or an H pipe (torque) then run them through some mufflers and i bet u like the results
Old 03-10-2007, 06:03 PM   #5
67Fleet
67Fleet's Avatar
Thanks, not sure I'll be able to accomplish that though. I'm setting my truck up to lay frame and I don't think I'll have room to put in an x-pipe.
-Bret
Old 03-10-2007, 06:21 PM   #6
regal8r
u can crossover the exhaust at any point between the headers and the mufflers...im sure u can find a way
Old 03-10-2007, 06:25 PM   #7
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Do you have the heat riser butterfly on that side?
low'n slow is offline   Reply With Quote
Old 03-10-2007, 06:31 PM   #8
67Fleet
67Fleet's Avatar
Yes, I've considered that to be a problem, but it feels like it moves freely when I move it by hand. Maybe it's broken? I've got some Sanderson headers that I'm putting on it soon, so we'll see if that is the underlying problem.
-Bret
Old 03-10-2007, 10:07 PM   #9
Texasdeere
Texasdeere's Avatar
I was thinking the same thing.
Texasdeere is offline   Reply With Quote
Old 03-10-2007, 10:25 PM   #10
dwaite72lnghrn
You sure you don't have a varmant ot bees in the pipe.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
