Old 03-10-2007, 05:03 PM   #1
long71
clean concepts
long71's Avatar
back half and air ride build thread
check it out here in the suspension forum
http://67-72chevytrucks.com/vboard/s...d.php?t=230890
long71 is offline   Reply With Quote
Old 03-10-2007, 05:09 PM   #2
regal8r
Re: back half and air ride build thread
looks nice. are you using the stock trailing arms as lower links? i have been thinking about running a setup just like yours. looks like u will get pretty good lift with that...is that a 2:1 lift ratio?
regal8r is offline   Reply With Quote
Old 03-10-2007, 05:15 PM   #3
long71
clean concepts
long71's Avatar
im using suicide doors super lift 4 link kit.
not sure on the lift ratio i just mounted the bags as close to the axle that i could safely... because of the angle of the frame they are a little closer to the pivot than i had originally wanted. about half way will give you good lift and good ride quality
Old 03-10-2007, 05:18 PM   #4
regal8r
ahh ic. do u have any more pictures at different angles? also, why no C notch?
Old 03-10-2007, 05:22 PM   #5
long71
clean concepts
long71's Avatar
i'll get some more pics
I built the frame high enough that no c-notch is needed. the entire frame is about 9 inches higher than factory
more pics coming
Old 03-10-2007, 05:23 PM   #6
regal8r
more pics coming
o sweet. awaiting pics
Old 03-10-2007, 05:27 PM   #7
regal8r
nice edit on the first post . that looks really nice. how long did it take you to backhalf?
Old 03-10-2007, 06:20 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
more pics coming
Sooo, will the bed be shallow then?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-10-2007, 06:21 PM   #9
long71
clean concepts
long71's Avatar
yep
