Old 03-10-2007, 07:34 PM   #1
mothertrucker424
mothertrucker424's Avatar
lift
i am fixin to order my lift and do i need a steering stabilizer and drop arm?
mothertrucker424 is offline   Reply With Quote
Old 03-10-2007, 07:38 PM   #2
bigtruck81
Re: lift
a little more info would be helpful
bigtruck81 is offline   Reply With Quote
Old 03-10-2007, 08:03 PM   #3
msgross
msgross's Avatar
Re: lift
how much lift? @ 4"+ I would do a steering arm or dropped pitman (helps reduce bumpsteer) and if you are running wide tires and/or over 33" then add a steering stabilizer setup.... Or do crossover steering and don't worry about it... How did those rims work out for ya?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-11-2007, 06:41 AM   #4
Re: lift
Double steering stabilizer mounted opposing each other for the push/pull effect.I`ve always done this and only see others do this with the horizontal design(That`s the only way with those).But,even a stacked Rancho set-up is best that way.They are dual-action shocks,but this still has got to be more effective I think.
Old 03-12-2007, 10:29 PM   #5
mothertrucker424
Re: lift
i am looking at buying the 4" rough country with rear blocks, front leafs, shocks, dual stabilizer(not sure how set-up is), steering arm for $550 shipped --i may also buy brake hoses--i run 33x12.5 now on 10" wheels i bought from "msgross"(by the way they work awesome) does anyone see a better deal or something else i need ?? thanks
Old 03-12-2007, 10:48 PM   #6
earl87gta
earl87gta's Avatar
Re: lift
if you dont mind used pm qksilver I think has a set of 4 springs for sale may save you some cash.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 03-15-2007, 06:55 AM   #7
mothertrucker424
Re: lift
were do ya'll get your dual steering stabilizer and will a blazer dual set up work on a 1/2 ton?
Old 03-15-2007, 07:45 AM   #8
msgross
msgross's Avatar
Re: lift
Those dual setup are pretty universal. One brackets clamps to the axle tube and the ends of the stabilizers clamp to the tie rod. I sold one on here a few months ago...
The Garage:
Old 03-27-2007, 06:42 PM   #9
mothertrucker424
Re: lift
ok i called rough country today and they told me 2 months till they would have front leafs so i said "i'd like to have my money back thank you" i called a local shop said i am looking for a 4" lift he said come see me tommorow i'll order it now he got me a 4" super lift and steering arm and dual stabilzer and shocks for like $600 i think he said and he over nights it and i can hold it tommorow install it this weekend and be broken by monday
I LOVE THIS COUNTRY
(sorry really excited)
what do ya'll think
Old 03-27-2007, 10:17 PM   #10
Re: lift
Mo betta!
Old 03-28-2007, 06:36 AM   #11
mothertrucker424
Re: lift
does the superlift ride better? or was the rough country better?
Old 03-31-2007, 05:23 PM   #12
mothertrucker424
Re: lift
got my lift today will post some pictures tommorow hopefully of it insatlled
Old 04-01-2007, 07:05 PM   #13
Biff
GM Gypsy
Biff's Avatar
Re: lift
Got any pics yet? I am thinking about doing the same thing.
1972 Custom 10 Deluxe LWB 4x4
2003 Power Wheels Barbie Jeep (2 daughters ya know)
2004 Silverado Crew Cab Z71- Sold
Here's to your coffin...
May it be built of 100 year old oaks which I will plant tomorrow...
Biff is offline   Reply With Quote
Old 04-01-2007, 07:50 PM   #14
mothertrucker424
Re: lift
here are a few i took today i just finished i wanna drive tonight and retorque everything tommorow
Old 04-01-2007, 08:01 PM   #15
Re: lift
Excellent!!Looks great.I like the un-resto look.
Old 04-01-2007, 08:04 PM   #16
mothertrucker424
Re: lift
its a work in progress i wanna do body work all in one shot then paint but motor first i wanna put my late model 2500 truck 350ci in first tehn body but its all a process and this one is funded poorly
Old 04-01-2007, 08:30 PM   #17
msgross
msgross's Avatar
Re: lift
lookin good, nice rims!
The Garage:
Old 04-01-2007, 10:32 PM   #18
mothertrucker424
Re: lift
ya i bought them dirt cheap and i think they look decent thanks for the wheels i need to clean them up ,they weight a ton too by the way
but
the ride is a little stiff but i'm hoping it breaks in and i need to adjust stabilizers no more u turns till i do and
how do ya'll get your steering arm off??
Old 04-02-2007, 03:53 AM   #19
earl87gta
earl87gta's Avatar
Re: lift
I used a cheap puller made to do the job from harborfraight tools I paid $6 for it.
if I can get the camra to work Ill snap a pic for you.
Earl
Old 04-02-2007, 11:21 AM   #20
msgross
msgross's Avatar
Re: lift
I beat the snot out of one before and then drilled on the cone washers a little (no recommended!) and ruined the studs. I won but inflicted a little damage on the knuckle...it was junk anyway...
The Garage:
Old 04-08-2007, 09:59 PM   #21
bigtruck81
Re: lift
i've actually got a broken stud in my 44. damn cone washer still wont come loose. will the knuckle come off without removing the arm? if it will, i'll take it to work and hit it with some heat.
Old 04-08-2007, 10:07 PM   #22
msgross
msgross's Avatar
Re: lift
the knuckle will come off after you remove the hub, spindle, axle shaft then loosen the ball joint nuts and knock the entire knuckle downward.
The Garage:
