Old 03-11-2007, 08:22 AM   #1
jdair
Need To Remove Some Paint
I got a console this weekend out of a 75 chevy this weekend and it's in really good shape. the only thing is they spray painted it white and it looks pretty rough. anyone know any kind of remover that will take it off without hurting the plastic???
It's better to be dead and cool than alive and uncool
jdair is offline   Reply With Quote
Old 03-11-2007, 08:34 AM   #2
watahyahknow
watahyahknow's Avatar
Re: Need To Remove Some Paint
think the best thing to do is covering it in vinil and leave the paint where it is .
if it not bonded too whell you could try soapy water or degreaser on a rag and rub it off but anything else prolly will attack the plastic
i tried sanding but it got me a lot of small barbs on the plastic that will show after paint
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-11-2007, 04:31 PM   #3
rust!!whatrust?
rust!!whatrust?'s Avatar
I would get some paint stripper and test it on something similar first. Most times I have used it I had no problem with it damaging plastic. Thats why it is in a plastic container alot. You may also ask a local paint store if they could recommend something.
Don't touch the Rust. Punk
rust!!whatrust? is offline   Reply With Quote
Old 03-11-2007, 04:36 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I sand blasted mine, and then used a spray bomb sealer. if you don't use a primer or sealer, then the spots that went all the way through on the lid will show through the paint
Old 03-11-2007, 04:43 PM   #5
herb101
Used Register
herb101's Avatar
I have heard that brake fluid works well of removing paint on plastic - but test it first. I have not tried it.
Castrol SuperClean also removes loose paint - I have used that one, but wear glove it you like the skin on your hands.
Herb
herb101 is offline   Reply With Quote
Old 03-11-2007, 05:05 PM   #6
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
I used a product called Tail strip paint stripper from advance auto. It worked very well and did not harm the plastic. I have tried some other paint stripper and had no luck with them.
Jason
jay_shy is offline   Reply With Quote
