Old 03-11-2007, 11:55 AM   #1
GMCMAX
Active Member
GMCMAX's Avatar
Rear spring hanger drop
After the 2wd to 4X4 conversion, I had to use 4" rear blocks to match the stock height on the front 4wd suspension. I just put a 4" lift on the front and did this to level it out. Still keeps the shackles right, and seems to drive good. I still am going to gusset the insides with a triangle piece, but I have to go to a friend's place for the welder.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 03-11-2007, 02:14 PM   #2
customcamper72
Re: Rear spring hanger drop
my 72 k20 chevy is the same color as your truck, complete with patina .
customcamper72 is offline   Reply With Quote
Old 03-12-2007, 07:40 AM   #3
1969K10
1969K10's Avatar
Looks good man, great idea!
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 03-12-2007, 10:22 AM   #4
jacobs
jacobs's Avatar
Another option you could have used is to rearch and add more leafs to the springs if desired.
jacobs is offline   Reply With Quote
