Old 03-11-2007, 04:51 PM   #1
rust!!whatrust?
rust!!whatrust?'s Avatar
Question Trick road handeling suspension.
Has any one ever tried to make one of these trucks handel? I like curvey roads and would like to auto cross my old truck ocassionally. I am aware of the cool parts from CCP. But I am curious about other peoples experiences even with salavge yard parts swapping.
Ricers hate it when they can't shake a farm truck. I am sure this probably isn't on most people's mind when they build their truck though.
Don't touch the Rust. Punk
rust!!whatrust? is offline   Reply With Quote
Old 03-11-2007, 04:59 PM   #2
Rokcrln
Rokcrln's Avatar
Re: Trick road handeling suspension.
You need to go to the suspention section and check out PorterBuilt and his suspention's that he is working on for our trucks. Can you say C4 and C5!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-11-2007, 05:53 PM   #3
SCOTI
SCOTI's Avatar
Porter has a soild starting point for a 'touring' based truck. One board member is well on his way w/his 77. Look for posts by member '7T7'.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-11-2007, 06:25 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Agree w/ the above, at the very least you can add front and rear swaybars
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-11-2007, 09:36 PM   #5
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I'm still trying to figure out which route my build is going but, if I stay 2wd this is also what I'm thinking. Nothing like a truck that can handle a curve like a sportscar. Dare to be different.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-11-2007, 09:36 PM   #6
see ten
WTB this ad
see ten's Avatar
You have to be careful with a rear bar if you have a lot of suspension drop. The guys I have talked to that run them say that they make the rear a little to unforgiving. You combine the stiffness of drop springs with a swaybar tieing both sides of the truck together you don't have much room for travel. Supposedly they want to break loose when encountering bumps in corners at speed. I have a front bar from a 1 ton and no bar at all out back. I know I'm far from being a G machine but it's a massive improvement over stock. If you like curvy roads you should go with us to Deal's Gap sometime!
see ten is offline   Reply With Quote
Old 03-11-2007, 10:54 PM   #7
rust!!whatrust?
What diameter is that 3/4 ton sway bar? My truck actually has a sway bar from the factory. I just stripped a 75 chevy school bus. The front sway bar was the same as mine. I think mine is about 1". Very good point about the rear I don't want to break lose when I am practicing my apexs. Deals Gap is definitely on my list of places to spend a day.
Old 03-11-2007, 10:57 PM   #8
SCOTI
SCOTI's Avatar
H.D. sway bars on 3/4 & 1-ton trucks are solid 1.25" bars.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-12-2007, 12:42 AM   #9
rauto13
saving one more
rauto13's Avatar
I had the CPP front & rear sway bars, 1/3 lowering springs & a close ratio steering box on my 72 longbed and it was a blast to drive around corners. It handled better than my stock 70 Camaro. The only issue with the rear end trying to pass the front end in a curve was after adding a posi and a little to much right foot action.
Other than that, the truck handled very well.
This website is for 2nd Gen Camaros, but has lots of good info on balancing spring rates and sway bars
http://www.nastyz28.com/pthandle.html
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 03-12-2007, 02:10 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
May 5, 2007 a bunch of us will be there
Old 03-12-2007, 02:50 PM   #11
neonlarry
neonlarry's Avatar
Another site to check out is:
http://www.hotrodstohell.net/
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-12-2007, 05:21 PM   #12
see ten
WTB this ad
see ten's Avatar
Having only 3" of drop out back probably made the difference for you. My truck has 6" of drop out back and doesn't have a lot of lean to it. Call Early Classic and ask them about adding a rear bar. Those guys get all but Irate when you bring it up. I also have an ECE quick ratio box. It makes it a different truck.
Old 03-12-2007, 05:50 PM   #13
Musclerodz
All the help is needed up front. The truck arm suspension will handle but needs to be tuned for ride height. Same thing NASCAR car's run. Rear mostly just needs a LONG panhard bar level at ride height, and GOOD shock, and GOOD tires. The front is a different story but itcan be made to work as well as long as it is planned out.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 03-12-2007, 08:03 PM   #14
rust!!whatrust?
Thanks guys keep it comeing I'm listening. We'll see if my engine is in by May 400sbc and 700r4. Stock suspension and 4 wheel manuel drums for now. I have a hydra boost that I snatched from the bus I got my engine out of. Plan on converting to disc up front, rear (we'll see), I love the idea of a 1 ton sway bar up front that's where i'll start my suspension upgrades. The issue of how much to lower a vehicle is interesting because most people lower their vehicle primarily for looks. I started out with the same frame of mind but pragamtism is moveing me away from that idea. Please forgive me for useing the word pragmatism and probably butchering the spelling.
Old 03-12-2007, 08:54 PM   #15
RACINJASON22
GEARHEAD
I don't know how to spell either but you might have got it right on one of your tries. pragamtism pragmatism now we need the definition. lol
Old 03-13-2007, 08:26 PM   #16
rust!!whatrust?
"pragmatism: a practical approach to problems and affairs." The New Meridian-Webster Dictionary.
It's when I am dreaming of a turboed big block in a protouring tuned rusty old truck. Then my wife walks in and I say "Honey I think I'll return this noisy cam kit and exhaust. It upsets the neighbors and we need milk and diapers too."
Old 03-14-2007, 01:22 PM   #17
speedracer
Blank
speedracer's Avatar
I have a 4-6 drop front and rear sway bars from cpp. A quick ratio box from cpp and 275 40 18 tires from a c5 vette. With the posi you have to be careful if you can get the tires to stick it will handle like a c5. I have autocrossed and its great, if you get too much momentum it starts to drift which is a blast because of the long wheelbase its really easy to control.
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 03-14-2007, 02:21 PM   #18
Orange
Licensed to Thrill!
Orange's Avatar
I've been watching this thread, and I've about just decided to call ECE and tell them what I want and dish out the dough.
BTW rust - I just noticed you were from Chattanooga.
There are a few of us from that area on here.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-14-2007, 06:27 PM   #19
Frizzle Fry
Frizzle Fry's Avatar
I've got a 1.25 front bar and Camaro rear bar with about a 4/6 drop on the Burb. Tires are 255/45/17 and 275/40/17. Also running KYB's. I'm taking it auto crossing this weekend with a Porsche club. Should be a good laugh, but I'm secretly hoping to be at least a little competitive
Frizzle Fry is offline   Reply With Quote
Old 03-14-2007, 11:02 PM   #20
rust!!whatrust?
you local guys should see me this summer around at local cruise-ins, the drag strip and such. Provided I get this thing back on the road. This has really helped me in my thoughts about suspension. I am definitely scoping yards for a 1 ton truck that I will be able to strip. CHEAP.
Old 03-14-2007, 11:18 PM   #21
dan42
dan42's Avatar
Does anyone know if that sway bar was stock on the one-tons?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-15-2007, 04:43 PM   #22
see ten
WTB this ad
see ten's Avatar
If you find a 1 ton with a bar, it's the big one!
Old 03-15-2007, 05:18 PM   #23
jimmydean
jimmydean's Avatar
I was looking at Porterbuilt's C4 front/rear and I decided I will use the standard Dropmember with Strong Arms instead of the C4 arms for the front.
My truck will be a mix of work/fun because I love driving my truck, but I miss driving a car sometimes. The article in Hot Rod a few months back where they tested air ride setups was very good. I think if you take it a step further than just air, you will make a truck rail.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-15-2007, 06:35 PM   #24
Frizzle Fry
I got my 1.25" bar off a 78 3/4 ton. The 73-87 bars are the same as the 67-72.
Old 03-15-2007, 06:40 PM   #25
Frizzle Fry
More sway bar info here including links to how to install a Camaro rear bar in post #8
