I'm a poor spectator
Weekend progress...pics soon to come.
I got tired of my clutch pedal squeaking like a banshee so I disassembled it all and greased it up to stop the ungodly noise. Next I decided that I needed more storage space for when I go fishing in a couple weeks so I decided to make a rack that slides into the reciever hitch on the back. I'll get some pics later to show it off but here are the basics. It's 4' by 2' and about 6 inches deep. I only need it to hold a cooler and a couple gas cans for long excursions. I also mounted some PVC to it for rod holders when i'm parked along the surf.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Can't wait to retire!!
Re: Weekend progress...pics soon to come.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
Future TOTM Winner
It looks like we are going to have to all pitch in and by J a camera. I think he is making all this stuff up!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Used Register
I'm waiting for the pics of that greased clutch pedal......
![]() Herb |
It better not be cheap, I want something good.
Just take my word for it.
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
I took my blazer around the block a few times but it ran really rough...so...I'm still not ready to take this thing over to one of yall's house. I might need some of your combined expertise on this one. I think I should probably do the plugs, wires, cap and rotor and see how it runs at that point. I did change the oil and put in a new air filter.
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon |
#9 | |
#10 | |
Future TOTM Winner
it idled really rough so we adjusted it and it seemed to run better, ie. it didn't want to die as soon as i put it in gear. it just feels like it's missing and i can almost hear an open vacuum line. so...did i ever mention that i'm a computer guy? forgive my ignorance...but what/where is the dwell? the fuel filter might not be a bad idea either. this thing sat for about a year with the PO and just about a year here also. i've started it about 8 times. i'm constantly being chastised by my brother (gearhead) for not starting it more often.
ooh....yeah the gas might be a problem also...it's pretty much sat in the tank as long as i've had it...i've added a bit...but not more than 1/2 gallon.
#13 |
weekdays aren't good for me but i'm pretty sure that my bro and i will be working on it this weekend. if you guys wanna come by, i'll let yall know for sure.
#14 | |
That's dwell for you but now i'm gonna explain why it works and why it would cause your truck to run rough. While the points are closed the current is flowing through the primary (+) post on the on the coil, flowing through the primary windings of wire inside the coil and out the negative post into the distributor housing and it grounds itself out through the closed points. While the current is flowing through the coil, a magnetic field is being created inside the coil ( it's one of the characteristics of electricity, if it passes through a conductor a magnetic field is created ). A certain amount of time is needed to build up the right amount of voltage, not enough time and you don't have a powerful spark (will run rough) and too much time and the coil reaches peak voltage and then the voltage starts to drop off ( again, will run rough). That's why you need to have it adjusted just right. When the points open up alot happens at once. Since the current can no longer move through the points and ground itself out the current stops moving in the coil and the magnetic field drops allowing the current to jump to the center of the coil called the secondary windings. When it does this the voltage multiplys many times into the thousands (25000 -50000 approximately depending on coil) and shoots through the secondary tower (where the spark plug type wire is hooked to that goes the the center of distributor cap) and is sent to the appropriate spark plug. That's not everything but it's enough, if you have any other questions just ask.
#15 |
well whenever this rain lets up...maybe you guys can come by one of these weekends
