Old 03-11-2007, 10:40 PM   #1
ChevyKid1500
4x4 Problem
Hello, I have a 1995 Chevy Cheyenne 4x4 truck, with a 305 5.0l V8 with a 5 speed transmission. I am having a problem with my four wheel drive. It has automatic hubs by the way. if i stop and put in 4 high, the lights wont come on show its in 4wd. if i put it in 4 low, the back locks in to the low gears, but the front ones will not pull. I have no idea of what it might be. any help would be greatly appreciated! ive tried everything shifting on the fly, backing up driving for a short distance to let the hubs lock in. it is so aggravating not to know what the problem is. Please help!! thank you so much in advance! ChevyKid1500 (Justin Roberts)
ChevyKid1500 is offline   Reply With Quote
Old 03-11-2007, 10:51 PM   #2
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: 4x4 Problem
you dont have hubs to lock.
this is a insanely common problem, its you actuator on the axle housing. it ingages the axle half so they arnt spinning free. they go out very often and very sensitive to abuse.
you can go get a new one or get a manual lever that will guarrante it locks every time.
also check all of the vacume lines and wires to the transfer case and axle.
trkklr77 is offline   Reply With Quote
Old 03-12-2007, 12:06 AM   #3
Re: 4x4 Problem
Dig you try to just wait awhile longer?They take forever to engage.I have 250,000 miles on my original actuator and it`s been that way since new.They need to "warm-up".
Old 03-12-2007, 12:42 AM   #4
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: 4x4 Problem
I would say 99% One of The Generals (GM's) shortcomings in my opinion.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-12-2007, 01:37 AM   #5
1969 GMC
1969 GMC's Avatar
Re: 4x4 Problem
Actually, I would broaden that one out to IFS in general. Shoulda kept the solid axles.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-12-2007, 02:08 AM   #6
CrashEd
72 chevy
CrashEd's Avatar
Re: 4x4 Problem
My 90 4x4 takes a while to lock in. If im stuck in two wheeldrive it takes even longer. I have to just ease it foward and backward. spining the back tires a little but it has always locked the front end.I figure if mine ever stops locking ill got to the cable setup for it that thay have now aftermarket.
CrashEd is offline   Reply With Quote
Old 03-12-2007, 06:49 AM   #7
Re: 4x4 Problem
I like a real truck and didn`t like the IFS idea.But,other than limiting off road modifications,it`s been a good thing for me.My`92 K3500 is like driving a car or 2wd 1/2t with it`s ride and handling(most time on the road).I bought it for work and work it did,and still is.It is rarely unloaded and what I`d consider empty would be about 8,000#net.I`ve only had to replace the idler arm ever 80,000 miles.At nearly 250,000,I think I`m on my 4th...original ball joints,axle CVs,boots,etc.I can load the bed,ladder racks,and haul a trailer @ 6,500#.My work on new homes requires the use of 4wd.Ever since they`ve offered the cable actuator,I`ve wanted to install one.They`re around $200+/- and I just haven`t gotten around to it.I`ve always wanted to do a solid axle swap,too,because it would be so cool.And,being a 1ton,it can be registered @ over 10,000# to get around lift laws.But it just keeps going and if it ain`t broke,don`t fix it.I bought it for work.I just play with my`72s.
Old 03-12-2007, 10:53 AM   #8
centsless
sufficiently talented fool
centsless's Avatar
Re: 4x4 Problem
There is a re designed actuator for this available from GM. It replaces the actuator with one that uses an electric motor. It works much faster and is more reliable. It is a two part kit. The actuator and a wiring harness. I have done this upgrade to many of those trucks and it makes a world of difference.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 03-12-2007, 06:40 PM   #9
ChevyKid1500
Re: 4x4 Problem
thanks for all the replies!! Centsless, how was the new designed actuator? and is it hard to replace? thanks!! oh i do have a manual lever in the floor, if thats what you were talking about trkklr77 thanks!!
Old 03-13-2007, 10:23 PM   #10
bloertcher
bloertcher's Avatar
Re: 4x4 Problem
I have the Posi Lock settup in mine,it's the only way to go!
IFS is the king of my work truck,love it.Not as strong,but drives nice and simple to maintain.
RIP Baby Jack 2-06-07
See You On The Other Side My Little Man
bloertcher is offline   Reply With Quote
