Old 03-12-2007, 01:15 AM   #1
Farmstore34
Farmstore34's Avatar
New owner of old truck has questions
Howdy all,
I (a lifelong mopar guy) have just purchased a 1970 Chevy K20 camper special pickup. Overall its in pretty good shape. I am trying to find out where the VIN number is located on the frame. I found a number on top of framerail beside the steering box but it doesn't look like a Vin number (more like a serial #). I believe the tag on the door jamb is not original. Any help would be appreciated. Thanks!
CT.
Farmstore34 is offline   Reply With Quote
Old 03-12-2007, 01:41 AM   #2
CRCustoms
Re: New owner of old truck has questions
i know the vin's are 12 digits long (as apposed to the modern 19 i think) some where around late 70s they swaped em over.
i used gmc pauls web page to decode mine. also, vin on cab is usually in glove box.
hope i could help, no idea on the frame rail vin.
CRCustoms is offline   Reply With Quote
Old 03-12-2007, 01:54 AM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Vin is on an aluminum tag attached to the cab...inside the door frame. The frame number is only part of the VIN but does/should match...you already found that. There is also a VIN on the glove box door, but these are easy to change/replace. Check your title and compare against all three. The VIN and title will always follow the cab, not the frame or glove box door...at least in WA State.
BTW...Welcome to the board from sunny Kent, WA!
There is place on this site that will help you decode your VIN or post it in this thread and we can do it for you.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-12-2007, 02:47 AM   #4
CRCustoms
can you decode mine? id like to verify the info...
CE140S152605
thanks for your help!
Old 03-12-2007, 02:53 AM   #5
regal8r
2wd
gas v8
1/2ton p/u
1970
built: st. louis
#605 built
regal8r is offline   Reply With Quote
Old 03-12-2007, 03:04 AM   #6
CRCustoms
wow that was quick. thanks regal8r
Old 03-12-2007, 03:23 AM   #7
regal8r
Old 03-12-2007, 07:22 AM   #8
Welcome to the site,Farmstore34.What emblem is on your fender,CustomCamper/20?Can we get pictures.We like pictures.
Old 03-12-2007, 10:09 AM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
Welcome to the board - look forward to seeing pics of your K20!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-12-2007, 10:14 AM   #10
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Welcome from South Texas, can't wait to see some pics!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 03-12-2007, 02:35 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Originally Posted by regal8r View Post
2wd
gas v8
1/2ton p/u
1970
built: st. louis
#605 built
Not quite acurate... close, but not quite.
CE140S152605
C ... 2 wheel drive
E ... V8
1 ... 1/2ton
4 ... cab and bed (not saying fleet or step)
0 ... 1970
S ... built in st. louis
152605 ... the 52, 605 built on that assembly line at that plant for the 1970 model year.
Old 03-12-2007, 03:24 PM   #12
CUSTOM/10
CUSTOM/10's Avatar
The last 8 digets of the vin # sould match the #'s you found on the frame. If they don't somethings been changed. Cab, Vin-tag, frame ext.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 03-12-2007, 11:56 PM   #13
Farmstore34
Thanks for all the info everyone! I will take some pictures very soon and post them. The Vin number and frame number don't match, and the VIN breaks down to a 1970 2WD 3/4 ton pickup. The suspension doesn't look cut up or modified in any way, so I suspect the cab or ID plate was changed at some point. Can't wait to start working on the old girl!
CT.
Old 03-13-2007, 08:05 AM   #14
Rick Mills
Rick Mills's Avatar
From Colorado. Lookin forward to the pics.
The Fastor Pastor
'68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed:
'70 swb; TH-400 - bagged & shaved. Looking for new engine or parts.
Wife - Original {A Real Classic!}
Rick Mills is offline   Reply With Quote
Old 03-13-2007, 09:24 AM   #15
killer71
killer71's Avatar
Welcome! Don't forget the pictures.
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
