Old 09-01-2002, 06:50 PM   #1
dave's70
1/2 and 3/4 ton frame differences?
Is there any differences between a 1/2 ton and a 3/4 frame. If there is what is it?
70 C-10 350 with weind intake,eldelbrock carb,HEI,305 heads,a mild cam. also a blazer tank w/bed fill,shaved stake pockets and tailgate
dave's70 is offline   Reply With Quote
Old 09-01-2002, 07:04 PM   #2
Gee_Emm
Cab mounts, there was some discussion on here before about the metal being thicker in the frame but I think that we had determined that to be false.
Gee_Emm is offline   Reply With Quote
Old 09-01-2002, 07:15 PM   #3
dave's70
does that mean you can't use a 3/4 ton cab on a 1/2 ton?
Old 09-01-2002, 07:22 PM   #4
Gee_Emm
No the cabs up to the 40 series I think are the same, I am assuming that the cab mounts are different though because the 3/4 tons use different cushions then the 1/2 tons.
Old 09-01-2002, 07:56 PM   #5
sakohntr
sakohntr's Avatar
cab mounts
Well let me start by saying that i took a 3/4 ton two wheel drive cab and put it on my 1/2 ton 4x4 shortbox with no problem. I did use new 1/2 ton cab bushings though. Everything mated up fine.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 09-01-2002, 08:20 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The cabs are the same 10-30.
The 1/2 ton 2 wheel drive has one mount.
All others have the other mount.
The frame on a 3/4 ton is thicker.
Old 09-01-2002, 08:39 PM   #7
Gee_Emm
I though there was a whole topic a few months back where ppl measured their frames and it turned out that they werent thicker????
Old 09-01-2002, 08:41 PM   #8
Longhorn Man
Tell you what, i'll go out and measure mine...I need a cigg now anyways. (no smokin in the house)
Old 09-01-2002, 08:47 PM   #9
Longhorn Man
Too dark, couldn't tell.
Blus I realized...I have a one ton...not a 3/4. (I think of them as the same since the Longhorns are the same 3/4 to 0ne ton)
If I remember, I'll measure in the morning anyways.
Old 09-01-2002, 09:42 PM   #10
ThreeQuarter
ThreeQuarter's Avatar
Yeah, I'm with Gee Emm. I thought everyone decided that they're all the same gauge thickness (redundant?). Anxious to see what we find out the second time, though.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 09-01-2002, 09:52 PM   #11
Longhorn Man
Either I missed that one, or i already forgot it.
I guess I'll take y'alls word for it.
Old 09-01-2002, 09:53 PM   #12
Beast388
Suburbans RULE!
Beast388's Avatar
I second what gmcblu said. I remember the last thread about this as well. I think that it was determined that they were all the same material thickness. But in case anyone wants to measure again, the frame on my 1/2 ton Suburban is formed from 1/8" material and measures about 6" tall right behind the front cab support frame bracket.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 09-01-2002, 09:55 PM   #13
Southpa
Southpa's Avatar
The next time I get hold of the ultrasonic unit from work I'll take a few shots of my frame and then compare with a buddy's 3/4 ton frame.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 09-01-2002, 10:40 PM   #14
Rod
The rear cab mount on the 3/4 ton frame is about 1 inch lower than a half ton frame. A half ton frame the rear cab mount is even height to the top of the frame. 1/2 ton 4x4 ,3/4 ton and 3/4 ton 4x4 and 1 ton trucks all use the same cab mount bushing... but a 1/2 ton 2wd is unto themselves and use a different height... actually smaller rubber cab support bushing.
There is no problemn swapping cabs just make sure you use the appropriate cab support bushing for your needs.
A C40 cab is different. Rod
Here is a pic of the rear mount on a 69 4x4 frame. See how its a little lower.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-06-2014, 05:55 PM   #15
Giljar
Re: 1/2 and 3/4 ton frame differences?
Anyone hawe the exact measure for how much lower the 3/4T is compered with the 1/2?
I hawe a 1/2 ton 69 and is replacing my frame mounts. By a mistake my new bushings ar for 3/4 ton, so my plan is to make new holes in the frame and put te mounts i the 3/4 location.
Giljar is offline   Reply With Quote
Old 01-06-2014, 08:14 PM   #16
72MARIO
72MARIO's Avatar
That is one thing I have yet to see and clarify.....I have to look in the am at my trucks see what the difference in frame mount locations is
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-06-2014, 08:59 PM   #17
k29349
Wondering if anyone here has tried to set a 67-72 k-10/k-20 on a 73 - 87 k-10/k/20 or even k-30 frame? How much of a pain was it?
k29349 is offline   Reply With Quote
