Old 03-12-2007, 02:10 AM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
Question rear piller bolt size ???
all,
i am hoping that this is a easy question. i am needing to know what the bolt size is & threads for the seatbelt bolt hole that is located in the rear piller behind the seat??? (for use with a 3 point seat belt.) i think it typically has a plastice cover over it. it is the hole in the upper part of the piller...
thanks!!!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 03-12-2007, 08:24 AM   #2
JimKshortstep4x4
Re: rear piller bolt size ???
The weld nut in the upper part of the pillar is threaded 7/16" x 20, NF thread.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-12-2007, 10:12 AM   #3
rodstored-72
chevy truck fan
jim
thank you!! for your time in answering my question, that is exactly what i needed to know...
p.s.: just out of curiosity how did you come about that very important knowledge??? if you don't mind sharing...
thanks again!
rodstored-72
Old 03-12-2007, 08:10 PM   #4
JimKshortstep4x4
I installed shoulder belts in my son's 71 C-10 and needed the bolts for the upper mount. I had some left over seat belt bolts with the 7/16 fine thread which fit the holes perfectly.
Jim
Old 03-13-2007, 10:58 AM   #5
rodstored-72
chevy truck fan
jim,
thanks again!! i hope i don't bother you too much with the questions..
what seatbelts did you use in your son's truck?? i have purchased a set from a mid '90's suburban..
do you think that they should work ok??
thanks again!!
rodstored-72
Old 03-13-2007, 07:26 PM   #6
JimKshortstep4x4
I used a set out of a 93 S-10. I really don't know if the belts you are looking at will work. Maybe someone else will post the answer.
Jim
Old 03-14-2007, 10:25 AM   #7
rodstored-72
chevy truck fan
jim,
thanks! i am going to try to get them to work. the length is there i just neeed to get the base for each side to fit better on the floor. they are a little chewed up though. what made you use the s-10 belts?i would think that they would be too short? also how did the belts fit on the base in relation to te cab floor??
thanks again!!
rodstored-72
Old 07-29-2012, 02:34 PM   #8
rodstored-72
chevy truck fan
Question Re: rear piller bolt size ???
well i dont know what happen, but i tried to put the bolts in ( 7/16" x 20, NF thread) and they do not fit (thread part) is it possible that the threads are different on my truck??? i don't know if the bolts are ""nf thread"" though.....
any help would be greatly appreciate!!!
thanks,
Old 07-29-2012, 03:00 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Wow...you just got around to this 5 years later?
7/16 20 (fine thread) is the correct size bolt for the pillar in all 67-72 trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 07-29-2012, 06:24 PM   #10
rodstored-72
chevy truck fan
well not quite what it appears, the truck has been put alltogether test drivin' & tore down for paint & body and now back together. i "lost" the bolts bought new ones & now i cant seem to get them to thread in what does the "nf" thread mean? should i just "wrench" the bolts in to make them work?? i do not have a tap that size, & would prefer not to buy one if that is all that is needed.....
thanks!!
Old 07-29-2012, 06:36 PM   #11
john
member #16
john's Avatar
7/16-20NF = national fine which is 20 threads per inch on a 7/16 bolt.. You will be better off if you can find 7/16-20 seat belt bolts because they are a shoulder bolt. Those holes would be hard to repair if you "wrench" the wrong bolts in.
john is offline   Reply With Quote
Old 07-29-2012, 11:02 PM   #12
rodstored-72
chevy truck fan
john, how would i go about finding these seatbelt bolts????
thanks!!!
