Old 03-12-2007, 12:34 PM   #1
combustion
tming issues
how many degrees of timing should i set my 454 to?? here is the set up,1994 454 gen 5 converted to carburetor with an eddie mani and carb with an HEI dizzy. my book says to set it to 4 degrees btdc, but since the whole set up has changed, then i'm not sure if to set it to the fuel injection set up. I JUST got finished with the swap, so i want to gt it running properly asap. thanx a lot
combustion is offline   Reply With Quote
Old 03-13-2007, 02:58 AM   #2
combustion
Re: tming issues
and up we go! lol, l throw i a pic to lure people .
Old 03-13-2007, 03:10 AM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: tming issues
my guess would 8* BTDC, looks nice to btw
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-13-2007, 03:38 AM   #4
combustion
Re: tming issues
oh ok, ya that is what my dad suggested, but i wanted to get a different opinion since he was not so sure either. but a, the picture does no justice, that flash shows all the imperfections i dont want it to show lol =P
il thro another pic just for the giggles
when i first got the motor
when i was halfway through my build
Old 03-13-2007, 03:54 AM   #5
GREASEMONKEY72
Re: tming issues
good progress, whats it out of?
-steven
Alte Seele S.S.
Old 03-13-2007, 04:07 AM   #6
combustion
Re: tming issues
if im not mistaking it was of a 1994 2500 p/u.
it has a eddie performer 2-0
750 cfm carb
carter fuel pump, (since the block cannot accept a mechanical one due to tbi)
the whole serpentine belt assembly
internal voltage regulator conversion
dual bolt patern hughes performance flexpate
HEI assembly.
and a electric fan assebly
i am still runing the th350. i hope it dont brake, it has never been rebuilt and its not designed to handle much power stock. plus i owe my dad quite a bit of money since i used all mine up in the fuel set up pretty much lol.
i found a picture of my old motor. it was and old and tired 307. i took it with my phonw thats why is a little blurry
Old 03-13-2007, 04:16 AM   #7
GREASEMONKEY72
Re: tming issues
the tranny will shift just fine right up till it burns up...i dont know what the hp rating for them is exactly but id probly rebuild it as soon as i could, sounds like a good set up though and im sure itll be fun to drive
-steven
Alte Seele S.S.
Old 03-13-2007, 08:38 AM   #8
cooters
Re: tming issues
you can never go wrong with power timing, this way you get the max adv that the motor wants without guessing. Max adv=max hp
cooters is offline   Reply With Quote
Old 03-13-2007, 08:47 AM   #9
Rascal_one2001
Rascal_one2001's Avatar
Re: tming issues
gota love the serp setup I need to steal the one that I put on my k5 for my c10 but looks good hopefully you can get that things running smoothly.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 03-13-2007, 10:00 AM   #10
Billla
Billla's Avatar
Re: tming issues
The simple answer is to set to whatever initial timing is required to get 36 degrees total advance (initial + mechanical advance) at < 3000 RPM. You can then tune the vacuum advance. I posted an attachment in this forum that details the process. This a proven approach for max power and driveability.
"Power timing" will always be far too advanced.
Billla is offline   Reply With Quote
Old 03-13-2007, 01:44 PM   #11
combustion
Re: tming issues
thanx a lot for your replies i will check that out for sure. you guys are awsome
Old 03-13-2007, 05:14 PM   #12
GREASEMONKEY72
Re: tming issues
could post it up here please?
-steven
Alte Seele S.S.
Old 03-13-2007, 06:20 PM   #13
Billla
Billla's Avatar
Re: tming issues
Here you go - this is the very best guide I've ever read, and Lars is a legend in the Corvette community with MANY success stories to tell.
Old 03-14-2007, 12:08 AM   #14
GREASEMONKEY72
Re: tming issues
thanks Billa
-steven
Alte Seele S.S.
Old 03-14-2007, 07:36 PM   #15
cooters
Re: tming issues
But Billla, what is to much timing when you say a smallblock can have 52 degrees advance? When it pings, its to much timing, no ping its good
