03-12-2007, 01:18 PM | #1 |
Which radiator to buy?
I'm trying to decide between a Griffen or Be Cool radiator. Anybody have some pros and cons for each brand?
Thanks in advance! Ronnie
1968 C10 Stepside 396 bored .030 TH400 |
03-12-2007, 01:46 PM | #2 |
Junior Member
Re: Which radiator to buy?
Hmmm...I kinda feel like a vulture doing this again, but here goes. Not sure which Griffin you're looking at, but the Be-Cool units are way over priced! I'm working on a new line of radiators for the '67-'72 trucks with nice fabricated tanks, and billet fillers, inlet/outlets. Also, aluminum dual fan shrouds, catch cans...etc. I cant say any $$ here, but these are not nearly as high $$ as Be-Cool. The pic rad is a different application, just for G.P. Send me a PM or email metalmassfab@gmail.com for more info and pricing
Ryan Metal Massacre Fabrication New Projects: -New radiator core supports, steel and stainless -Aluminum radiators -Aluminum dual electric fan shrouds '69 C-20 Custom '69 Nova...BIG BBC soon '72 3-door 'Burb...in a few '94 K2500 454 'Burb |
03-12-2007, 01:53 PM | #3 |
Active Member
Get with Shifty. He went thru an ordeal to find the best rad for the buck for his truck.
Sonny |
03-12-2007, 02:30 PM | #4 |
Unless you need something that is pimptastic, just put on a factory style 4 core, available at any radiator shop. If you run an automatic, the 4 core (big block) radiator has a bigger integral hydraulic oil cooler, it goes from 7.5 inches long to 11.5 inches, measured from inlet to outlet.
03-12-2007, 03:03 PM | #5 |
I'm really worried about cooling issues. Before I rebuilt the engine, I couldn't let it idle too long or sit at a drive thru without it getting too hot. I rebuilt it and bored it .030 and went to do the break-in, but couldn't let it run long enough to properly break it in due to getting too hot. It had a 3 core in it and I know the very least I need to do is get a 4 core, but from everything I've read aluminum is much better. The truck had to sit a couple of years before I could get it back up and running and the radiator turned to crap during that time.
It may be overkill, but I have an eating problem and like to go through Burger King drive-thrus without overheating.
03-12-2007, 04:13 PM | #6 |
4 core and an aux tranny cooler should work, depends on how hot your cam is. Check your fan clutch, it could be letting you down.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. |
