Old 03-12-2007, 02:26 PM   #1
arkracing
Weekend Warrior
What are you guys doing about the rust on the inner bedsides??? - Picts inside
How have you guys been handling this situation - I know that it is pretty common for these trucks. Luckily the P.O. drilled about 50 1/8" holes under the rear wheel arch - so the outers didn't rust, but the inner panels where it attaches to the wheel house are a little "soft"
What would you do?
This is the Driver's side rear (the worst of it - the pass side only has a couple small holes that can be patched pretty easy)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-13-2007, 08:28 AM   #2
arkracing
Weekend Warrior
Re: What are you guys doing about the rust on the inner bedsides??? - Picts inside
What nobody's had this problem?
Did you make a patch? - and how did you do it?
-'66 C10 Suburban
Old 03-13-2007, 08:34 AM   #3
cooters
i had to cut out a piece of a boxside that was not rusted on the inside, but was no good on the outside
cooters is offline   Reply With Quote
