03-12-2007, 02:58 PM | #1 |
Quick Engine Timing Question!!
350 engine. #1 piston at tdc (right side looking at engine. rotor on #1 plug, but which rocker is up, first or second? Trying to get it back in time before the install since I had the dizzy out and installed pulleys and think I turned the engine a couple of times. Thanks in advance!
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-12-2007, 03:43 PM | #2 |
GEARHEAD
Re: Quick Engine Timing Question!!
Neither rocker should be up if correct.
check this thread http://67-72chevytrucks.com/vboard/s...d.php?t=225820 |
03-12-2007, 03:59 PM | #3 |
THanks for the link. As I was doing it I remembered a trick I was taught and tried it. I wadded up a piece of suran wrap and stuck it in the #1 spark plug hole. As I rotated the engine on the compression stroke it popped out the piece of wrap. I took a look at the rotor and it was at #1 position, and neither rocker was up, so I had it right. THanks for the link though, it was informative!
shawn
03-12-2007, 04:18 PM | #4 |
GEARHEAD
I would not turn the engine over with the key while the suran wrap it in the hole. If you were on the wrong stroke it would be sucked in, NOT GOOD. FAQ section has alot of good tech. RJ22
03-12-2007, 05:54 PM | #5 |
tHanks!! THe engine is out and sitting on a stand.I did it and the suran popped right out on TDC. I am good as far as that goes, now for the tranny difficulty....
SHawn
