Old 03-12-2007, 03:56 PM   #1
underdog8704
NCStroker
underdog8704's Avatar
Which Holley?
I am looking at putting a new carb on my 383 stroker. The edelbrock 650 isnt delivering enough fuel on the top end. What are your guys opinions on the Holley Street Avenger 770. Pros-Cons? Any other opinions will be much appreciated. Thanks for the help.
1971 Chevy C/10-Built 383 Stroker
underdog8704 is offline   Reply With Quote
Old 03-12-2007, 04:02 PM   #2
70GMCer
70GMCer's Avatar
Re: Which Holley?
I would also like too know, as I am going to build a 383 and not sure which carb to use.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 03-12-2007, 04:07 PM   #3
martinkh
Re: Which Holley?
My intention also, but mine will be for off road use, which means a smoooooth idle and plenty of area under the torque curve, vs. high peak HP. So for me, a 650 quadra-jet is the answer. Some places do sell tuned-up q-jets, and a 750 is available.
Holley isn't worth crap off road, unless you like to alternate between flooding and starving, and enjoy keeping a screwdriver (or allen/torx wrench) in your pocket for those fun emergency tuneups.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift.
'77 400sbc, '82 axles, d60front, 14bolt rear.
Probably some 285/75/16 Toyo m/t's on my stock rims coming up.
martinkh is offline   Reply With Quote
Old 03-12-2007, 04:11 PM   #4
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Which Holley?
What are your determing factors to let you know your 650 edl. is not delivering enough at the top end.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-12-2007, 04:38 PM   #5
rophle1
rophle1's Avatar
Re: Which Holley?
I will let you know in a couple of weeks. I bought the 770 avenger and hope to have it installed and going soon.
1968 C10 Stepside
396 bored .030
TH400
rophle1 is offline   Reply With Quote
Old 03-12-2007, 06:03 PM   #6
stepside454
stepside454's Avatar
Re: Which Holley?
how much RPM are you looking at in the top end ? If its starving for fuel...thats not really a carb cfm issue. Does Edelbrock even make a 650 CFM carb ? anyway 650 cfm should support up to 5500 RPMs on a 383...maybe a lil more.
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 03-12-2007, 06:15 PM   #7
71chevylowrider
71chevylowrider's Avatar
Re: Which Holley?
just for reference, the Edelbrock 1406 is a 600cfm, but the Edelbrock thunder AVS series comes in a 650cfm, & an 800 cfm.
71chevylowrider is offline   Reply With Quote
Old 03-12-2007, 06:24 PM   #8
stepside454
Re: Which Holley?
thats right, I forgot about the AVS model
Old 03-12-2007, 06:29 PM   #9
b&a72
Active Member
b&a72's Avatar
Re: Which Holley?
I run a 750 double pumper on my 383 and it runs great.
b&a72 is offline   Reply With Quote
Old 03-12-2007, 06:37 PM   #10
underdog8704
NCStroker
Re: Which Holley?
My reasoning behind this is that if I floor it it goes up to about 80 and fails to go any further. It acts like it wants to but hesitates. At other times I can jump on it and it really acts like its starving for fuel. Example being when I manually shift it from first into second, and keep it floored, it hesitates real bad. If I let up and floor it again, about half the time it does fine. Any other opinions would be great. Thanks again for the help.
Old 03-12-2007, 06:39 PM   #11
underdog8704
NCStroker
Re: Which Holley?
it could be a 600cfm carb. It is the edelbrock carb and intake that originally came on the truck. I did the rebuild and figured that combination would be sufficient.
