03-13-2007, 12:01 AM | #1 |
Painting Master Cylinder
Do you have to paint a master cylinder to keep it from rusting? Or can you jsut clear coat it?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
03-13-2007, 12:09 AM | #2 |
GEARHEAD
Re: Painting Master Cylinder
I have bought meatal cast clear some wher before, Used to paint directly over bare cast but I'm not sure where. I'm not real up on the paint side of things so I can't say if reg. clear will do the trick or not. RJ22
03-13-2007, 12:13 AM | #3 |
Maybe a coat of grey and a coat of clear. Lets see what that does
03-13-2007, 12:17 AM | #4 |
GEARHEAD
If you are going to paint then I do know that just your local auto parts store sells metal cast finish the clear over that will work for sure. I just could not remember were I came across the clear that was for directly over raw cast.
03-13-2007, 12:23 AM | #5 |
Instead of painting coat it with this stuff it works wonders on many cast surfaces.
http://www.calyxmanifold.com/
The puppy barks but the trucks roll along. |
03-13-2007, 12:34 AM | #7 |
It will probably come off. I found some high temp cast grey. I used that. I blocked off the inside so nothing got in there.
03-13-2007, 08:38 AM | #8 |
I cleaned mine up and painted it with a few coats of high temp paint to match my engine and once it completely dryed it seems to be resistant to brake fluid but im not gonna dump fluid all over it to see how resistant.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s |
03-13-2007, 10:03 AM | #9 |
I've used Eastwood's "Cast Blast" on mine - holds up very well if you clean the cylinder very well and put on several light coats. Mine is 9 years old and still looks great.
03-13-2007, 10:21 AM | #10 |
Gibb's penetrating oil is supposed to work very well at protecting bare metal, but it's pricey from what I understand.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
