Old 03-13-2007, 12:57 AM   #1
70GMC396
Kickdown Switch
Anyone have trouble with your kickdown switch (w/TH400). Mine fell apart yesterday - the electrical connector and I will have to figure out which + and - lead goes where. Just use continuity testor I guess. It has 4 places to hook the leads up in a square pattern. + looks like it connects to passenger rear, but the negative lead fell out of the fractured connector. Also, the switch is very gummed up - anyone recommend best way to recondition it. I don't think it has been free to move for awhile.
70GMC396 is offline   Reply With Quote
Old 03-14-2007, 10:51 PM   #2
70GMC396
Re: Kickdown Switch
wow - no one have any problems with this part???
Old 03-15-2007, 05:20 AM   #3
JimKshortstep4x4
Re: Kickdown Switch
I don't believe that there are that many TH 400's with the carb mounted kick down switch. My guess is that most guys would replace them or go without the function.
Replacements are available for the switch.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-15-2007, 08:48 AM   #4
cooters
Re: Kickdown Switch
The kick down switch does not have a + and a -, it is just power in and out.
cooters is offline   Reply With Quote
Old 03-15-2007, 11:11 AM   #5
Frizzle Fry
Frizzle Fry's Avatar
Re: Kickdown Switch
Do a search on here or google for th400 Lokar kickdown. I have their switch as well as a few other members here and it is well worth it! Don't go without the function. It's a pleasure to drive with the proper kickdown.
Frizzle Fry is offline   Reply With Quote
Old 03-25-2007, 11:50 AM   #6
70GMC396
Re: Kickdown Switch
Thanks guys - I'll fix it for now.
Old 03-26-2007, 01:04 AM   #7
70GMC396
Re: Kickdown Switch
Fixed it - FYI the rear 2 post are the normally open circuit - completes circuit at WOW for trans downshift - the cool part is the front 2 posts (unused on my factory setup) which are normally closed circuit UNTIL WOW, then becomes open (posts are marked for relay and sw)
