Old 03-13-2007, 02:02 AM   #1
byates2
byates2's Avatar
Water Pump question
I got a 67 C10 with a 283. I want to put a 350 in there. When did they start using the long style water pump, i heard that it may not fit and i could use the short style pump off the original 283 and it should fit good with regards to the radiator and fan shroud, would the short style water pump be able to cool the 350 or can i just go with the long style pump, does it fit in a 67?
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 03-13-2007, 02:11 AM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Water Pump question
Your short pump will work with the 350 swap. I would use it that way all your brackets and parts will bolt up nicely, and look stock for your truck. I have never heard of a short pump cooling less than a long for that matter. Good luck with your truck and swap. RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-13-2007, 02:14 AM   #3
FLEET72
FLEET72's Avatar
The long pump fits fine. But why switch if you already have all the accessory brackets for a short pump. '73 for the truck line to utilize the long pumps.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-13-2007, 02:18 AM   #4
byates2
byates2's Avatar
Well the only other mount i have is the alternator, it has manual steering, i'm adding power steering myself after the 350 is in there, would that matter if i had the short pump on there?
Old 03-13-2007, 02:23 AM   #5
RACINJASON22
GEARHEAD
I would still go short IMO and stay true to the truck. You could go either way easily though.
Old 03-13-2007, 02:28 AM   #6
byates2
byates2's Avatar
Ok thanx for all the advice, yea i'll probably go with the short pump
Old 03-13-2007, 02:37 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
the difference between the short and long pumps is for clearance issues, atlest thats all ive ever heard
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
