Old 03-13-2007, 09:12 AM   #1
danny7481
fuel guage does not work correctly
my fuel guage does not work correctly in my 2000 gmc seirra, whenever i fill it, usually it says low fuel for a few minutes then goes up, and sometimes itll bounce back and forth rapidly, its strange. i was wondering exactly what part causes this, is it easy to replace and is it worth replacing? thanks.
danny7481 is offline   Reply With Quote
Old 03-13-2007, 10:01 AM   #2
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
Re: fuel guage does not work correctly
replace the float and or sending unit in the tank
'85 swb
droppedgmc is offline   Reply With Quote
Old 03-13-2007, 10:01 AM   #3
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
it's pretty easdy to replace, 2 bolts and the tank drops
'85 swb
Old 03-13-2007, 09:01 PM   #4
danny7481
is it the fuel tank sending unit or fuel level sensor?
Old 03-13-2007, 10:34 PM   #5
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
the way you describe it sounds like a level sensor
'85 swb
Old 03-14-2007, 08:11 AM   #6
danny7481
when it has a full tank the needle wants to stay on empty, when its 3/4 - 1/4 the guage works correctly and when under a 1/4 it wants to say empty. my friend has a 99 sierra and his stays on full all the time, no matter what. must be a common problem with gmc's.
Old 03-14-2007, 08:12 AM   #7
danny7481
where is the level sensor? inside the gas tank?
Old 03-14-2007, 10:48 AM   #8
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
it's all 1 unit in the tank. i've had to replace mine for the same reasons
'85 swb
Old 03-14-2007, 12:50 PM   #9
danny7481
i hope this is what your talking about, cause i just bought one
http://www.replacementautoparts.com/...meter&s=1&my=1
Old 03-14-2007, 02:47 PM   #10
C-Notes
C-Notes's Avatar
Mine does the same thing. I've gotten use to it and now I just double check it with my mileage.
Daily: 2001 Silverado 2500 4x4
Future Project: 1970 C-10 Stepside
C-Notes is offline   Reply With Quote
Old 03-15-2007, 01:09 PM   #11
Joe67
67 is sold
This is a very common problem on the NBS 1999-2001 trucks. It is your fuel sending unit.
I finally replaced mine two years ago, new sending unit ran about $210 from the local auto parts store.
Unbolt your bed, pull it back about 1 foot, the entire job should take just over 1 hour with a couple of guys and the proper tool to remove the lock ring on top of the fuel tank
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-15-2007, 05:42 PM   #12
danny7481
when you pulled the bed back, you didnt have to unplug the tailights or unbolt the filler neck from the gas tank?
Old 03-15-2007, 11:06 PM   #13
Joe67
67 is sold
Yes, you need to do that as well.
We actually dropped my tank, did it the hard way Thank god for the Trans Jack I had sitting in the garage... Next time I'd pull the bed back - MUCH easier
Old 03-16-2007, 10:08 AM   #14
danny7481
could someone verify that the item in the link above is the right level meter. just want to make sure i bought the right part, thanks.
Old 03-17-2007, 12:10 AM   #15
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
it says it's a universal...try going to a parts store and see what they offer
'85 swb
Old 03-17-2007, 03:20 PM   #16
TDs6t9
TDs6t9's Avatar
The one on my '99 silverado does the same thing. I just reset the tripmeter and go on my way. If I have to do some weekend work to it, I'll fix it then.
TDs6t9 is offline   Reply With Quote
Old 04-29-2008, 09:19 PM   #17
TravRMK
TravRMK's Avatar
danny7481, did you ever get this fixed? My 00 GMC does the exact same thing. I also have a friend with a 01 Silverado that also does it. We would like to know what fixes it. If that $30 part does it then great. I would have thought it would be a dealer only part. I guess I should ask the local Napa guy if they can get them.
TravRMK is offline   Reply With Quote
