Old 09-01-2002, 08:56 PM   #1
orange71
ac brackets
Hi i am a new member and i have a question. I was re painting my ac brackets and i installed them back on and now the adjusters on the valve cover bracket and the one on the manifold, that goes to the compressor, run out of adjustment before the belt is tight. can someone plaese help me out. all info will be greatly appreciated. i hope someone understands what i am trying to tell!!!!
orange71 is offline   Reply With Quote
Old 09-01-2002, 09:13 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Is there also one on the front of the compressor? That goes to the water pump mount? You might try checking that. Seems like it makes the most difference in adjustment. Also check to see if you flipped the intake bracket backwards. jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 09-01-2002, 09:21 PM   #3
orange71
Thanks for the reply! i checked the brackets that go across the valve covers and the one tha goes across the intake. the proble is still there and i put everything back the way it shows in the manual. it seems like the belt grew a little bit but it didnt!
Old 09-01-2002, 09:27 PM   #4
woodrow59
OzarkHillbilly in Atlanta
Just my opinion ,,,,, the bolts that go into the manifold and valve cover bracket are not adjusters ,,,, they hold everything tight after you adjust the bolt that actually holds the compressor to the bracket.
Also if you painted the bolts they're gonna glog up the threads.
Another trick ,,,,, If a bolt doesn't seat where you want it to, put a washer(s) on it. Not a permanent fix but might get you by in a jam.
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 09-01-2002, 09:36 PM   #5
orange71
My problem is that i cant adjust the belt because the adjustable brackets that go across the valve cover and the manifold stop before the belt is tight. it seems like I put one on the brackets that go to the water pump or the one that connects to it, backwards or something.
Old 09-01-2002, 10:13 PM   #6
orange71
ttt
Old 09-01-2002, 10:18 PM   #7
Yellow Cheyenne
Did you possibly mix the alt belt with the AC belt? I don't remember for sure, but think they may be fairly close in length. If you replaced belts with new ones, are they the correct parts? The parts stores around here are always trying to give me the incorrect ones. Good luck.
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 09-01-2002, 10:21 PM   #8
orange71
the ac belt is a gates belt with the numbers 7075 on them everything fit before i messed with it, now it is off. i cant see anything wrong with the setup(it came off the same truck).
Old 09-01-2002, 10:22 PM   #9
orange71
thanks for the help i am still trying to figure this out!!!!!
Old 09-01-2002, 10:35 PM   #10
Yellow Cheyenne
My pickup is a '72 with AC, PS, and altenator. Can't look at the pickup, but my records show that I run a Gates 8555 for the AC belt and a Gates 7530 for the Altenator belt. The AC belt goes around the crank, water pump, and AC compressor. The altenator belt goes around the crank, water pump, and altenator. The PS pump has its own belt. Hope this is correct and that it helps.
'70 Olds Rallye 350
Old 09-01-2002, 10:48 PM   #11
orange71
Yellow cheyenne
I am running the same setup that you are but my ac belt is a 7570 and i tried to switch the alt belt with the ac belt and it is impossible to do that so i knwot thay they werent switched but i still cant find the problem. i am going to try and get the belt that you are running on your truck to see if it matters
