Old 03-13-2007, 12:41 PM   #1
paaw
paaw's Avatar
tranny help
got my 700r in shifts through the gears great, only thing is that it is not down shifting, thought cable wad adjusted right, an suggestion, or is there a tranny shop around nashville that adjust trans with carbs
Chico
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold
paaw is offline   Reply With Quote
Old 03-13-2007, 01:47 PM   #2
Sonny
Active Member
Re: tranny help
What are you using to control your OD (TC lockup)? There was a thread that had some pics to set the valve (you have to drop the pan). Once that is set you use a pressure gauge to dial it in. How much slack is in your cable?
Sonny is offline   Reply With Quote
Old 03-13-2007, 02:50 PM   #3
paaw
paaw's Avatar
Re: tranny help
not really anylack in the line, it just didn't click out any when I adjusted it
Old 03-14-2007, 07:57 AM   #4
Sonny
Active Member
Re: tranny help
I would seek out a shop fairly quick then before you burn the tranny up. The tranny can tolerate being out of adjustment some but if they are pretty far out and your line pressures are way off you will burn the tranny up.
Sonny
