Old 03-13-2007, 06:22 PM   #1
lilbuster20
lilbuster20's Avatar
Never heard of it.
In my 84 scottsdale, I have what they call a 350 lockout tranny. In the last gear it bogs down as if it was a overdrive tranny. The problem I am having with it is when you go to slow down, it jerks like hell. My question is this. Is this tranny worth rebuilding or would I be better off getting a 350 turbo? Any suggestions?
lilbuster20 is offline   Reply With Quote
Old 03-13-2007, 09:11 PM   #2
grinch4om
dang its hot
grinch4om's Avatar
Re: Never heard of it.
it's a 350 lock up trans, the converter is staying locked up, check brake switch area for the disengage pedal switch,(check a schematic to make sure it does or doesn't run through the brake light circuit.) I'd get a 700r4 but it depends on what you are doing with the truck. The 350 lockup trans do fine if cared for and you are not doing wheelies...
grinch4om is offline   Reply With Quote
Old 03-13-2007, 10:27 PM   #3
82c10
needin' money
i'd get a non-lockup th-350 if it was me
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 03-13-2007, 11:16 PM   #4
strokd 84
strokd 84's Avatar
Mine came with the lock out also. Once I switched from the 305 (gutless wonder) to my current 383, the lock out didn't last long. I switched to a Turbo 350.
1984 Silverado SWB
Second Owner
Featured in Custom Classic Trucks May 2013
http://www.customclassictrucks.com/f...let_silverado/
strokd 84 is offline   Reply With Quote
Old 03-14-2007, 10:46 PM   #5
lurch115
lurch115's Avatar
from what i have seen of the 350th lock-up trannies is that when you put any kind of power infront of them that clutch in the converter doesn't last long...they were a weak design in those trannies...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-15-2007, 06:55 PM   #6
lilbuster20
That's what I was thinking on doin. 700r4. Will it hook up like the tranny I already have, or will I need to do some adjustments?
Old 03-15-2007, 07:34 PM   #7
grinch4om
dang its hot
grinch4om's Avatar
yes a 700 r will live. again, depends on what you are doing. I have one in my big block truck . make sure you get trans from 1987 up as the imput shaft is stronger and bigger. Get a vette or similar servo for the band. kevlar clutches, manual valve bodies are available if you need one. TCI and other companies make loose converters that lock up and also stand alone electrics for lockup. I have a 2400 converter,superservo and the good clutches. smoke the hides as far as you want. If I were drag racing I'd go with a 400 or 350 turbo but for the street and a truck that basically wont see slicks, the 700 is cool.
